Question about Brother MFC 7420 All-In-One Laser Printer
Four dots middle of page
Four dots print going down the middle of page either copy of printed..
toner seems fine, but should I change it to a new one anyway? there is nothing on the glass, etc.
  • 1 more comment
  • cmaponte Nov 25, 2008
    Same printer, same problem. Four dots making a column alligned around 1 inch from the left margin.
  • sloweddie Dec 11, 2008
    Same problem: 4 dots appear vertically down each printed page approx 3cm from right edge. I have inserted a new toner cart but this did not fix it.
  • solidtearz Mar 16, 2009
    ummm.. sorry, but i didnt understand the last post. so basically there is nothing i can do to get rid of the 4 dots that run vertically down the page ? except buy a new drum ?
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Posted on Feb 02, 2011
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Check fusing unit
Posted on Dec 28, 2013
    Champion:
  • 320 Answers
Take the drum cartridge out and look at the drum. lift the flap up and make a copy it will come out black. thew dots will show. if you measue from dot to dot that will be the circumfrence of the drum, either live with it ir replace the drum make sure that you are using brother oen drum and toner, generic toner will ruin the drum good luck brother sr tech
Posted on Jan 24, 2009
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
b. Press the up or down arrow key to select OFF and then press OK.
c. Press Stop/Exit.
2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
Oct 26, 2010 | Brother MFC-9840CDW Laser Printer
Black dots on printed page from Brother 9440 color laser printer
The problem lies with the black toner cartridge. This is a common problem in these machines due to poor design by Brother. Best solution is to replace the offending color toner cartridge.
Jan 18, 2010 | Brother MFC-9440CN Laser Printer
A black line is printed down the middle of pafe
The problem may be from either from the toner cartridge or the settings of the printer. change the toner first and see whether he problem still persist and also make sure that the settings of the printer on your system is ok, if the problem still persist after doing all this then it implies that you need to service your printer.
Sep 25, 2009 | HP Office Equipment & Supplies
Printing black line down middle of page when coping
The fuser is located in the back of the printer. I think it's held in by to screws. It's about hte same size as the toner cartridge. Please visit these websites.
This is the fuser kit.
http://store.printerprinciple.com/products/rm1-3044
The service repair manual.
http://www.scribd.com/doc/15253671/HP-Laserjet-3055-Repair-Manual
Fuser Replacement is on page 170.
Aug 08, 2009 | HP LaserJet 3050 All-In-One Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
Brother MFC 7420 All-In-One Laser Printer Logo
648 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
