Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Can't find internet.
I got a new Dell Vista computer downstairs here the modem and router are. The problem I am having is: After installing hardware by the directions and setting up everything the wireless computer upstairs gives the message: Communicating with router but internet could not be found.l
Thanks, R. Tucker
  • g8_53 Feb 27, 2009
    Linksys 802.11g/b Wireless Adapterwireless adapter software is installed, hardware installed.. no networks can be found. It was working fine in the other pc, this is a new dell with vista. device manager says the hardware is working properly.
  • Ved Pradhan May 11, 2010
    i want to know how you are trying to conect to the wireless network,are you using the windows utility or the linksys card utility??i suggest you to use the windows utility and not the card utility....let me know for further help...
  • 3 Answers
Check the ip address on the wireless network connection icon,make sure that the ip address,make sure it is dhcp enable and is within the same range with the router may also change the channel on your router because the problem is may be with wireless interference,you may be using other wireless devices that are running within the same frequency as your router.(cordless phone,baby monitor talk,microwave ovens,even thick walls and large aquariums)
Posted on Jul 30, 2009
Cannot connect to the internet
Reboot your modem, then reboot your new router.
The rebooting is an essential process of installing a new piece of hardware to a modem.
When your modem boots up it leases an IP Address to the MAC Address of the first connected piece of hardware (router in your case). If you switch hardware without rebooting, your modem will not recognize the new piece of hardware because it has a different MAC Address. Every piece of hardware has its own MAC Address, unless it has been cloned.
Feb 25, 2010 | D-Link AirPlus DI-524 Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Changed my modem and now my wrt160n dosen't work
I recommend calling your ISP and have them synch your new cable modem with their connection. They may need to register the hardware address of your new modem for them to be able to recognize it and grant internet access.
Hope this helps.
Jun 25, 2009 | Linksys WRT160N Wireless Router
Cannot get internet connection on pc with wireless adapter
The LAN will really tell you that its disconnected since your computer downstairs is not connected with a cable to the router, the only problem here is the wireless PCI adapter is not installed properly, try to run again the setup CD for the adapter and make sure you restart the computer when the installation is complete...
Dec 01, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router not working as well with D620 as with my older D610
If your router has the external antenna the signal will increase when you point the antenna in the direction where the computer is used the most. It always helps to locate the router in a central area and on the upper floors of a house because the broadcast signal falls like rain. Another trick to try is to change your broadcast channel in the router, the normal default is channel 6. Each channel broadcasts at a slightly different frequency. Hope this helps...Tennis123
Nov 05, 2008 | Arris Wireless G Broadband Router (wr850g)
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
New Laptop Will Not Connect
The first thing u need to do connect ur router to the computer with a wired connect access the router page (firmware) ip address which need to enter to open the same on internet explorer is enter the user id & password of router (default user id & password is admin or password)
step 1 go to wireless change the channel to 6 (this the best channel)
Step 2 go to add/remove in control panel remove the dell wireless utility
step 3 go to device manager in control panel go to network adapter right click on wireless network adapter & select uninstall or remove
step 4 Now click action on top of device manager & click on scan for hardware changes it will reinstall the driver
Step 5 now go to network & sharing center go manage network connection right click on wireless network connection & select the connect it will show the list of wireless network now connect to ur network enter ur security key once ur connected save the network & ur issue is resolved
Jun 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
202 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
