Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
Compresser kicks on and off frequently
Good Morning, My compressor in my Kitchen-Aid refridgerator kicks on and off every minute or so. Starts out with a loud hum and ends up with a click. Coils on the bottom are clean and the airflow in the refridgerator and the freezer compartments are not restricted. Any suggestions.
Thank you
Debbie
  • 76 Answers
Hey Debbie....
that's only one thing....The compressor is down to earth.
The only way to fix this is to replace the compressor..
After 10 years i no this symptoms, im a cooling tec with my own business.
If you want to get a other opinion feel free but i guarantee you 100% that's the problem.
Sorry for the bad news...
Regards
Wouter.
Posted on Sep 11, 2008
How much is a new compressor for a kitchen aid refridgerator
Total repair about $500+ (average repair about $700) and would require a qualified professional to do the repair. Don't think I have seen that model need a compressor normally it's just the starter relay on the compressor.
Mar 14, 2013 | Whirlpool GS6NBEXR Side by Side...
Maytag side-by-side MSD2454FRW refridgerator has stop refridgerating. Fans are running, lights work - not sure about compresser. Wife say she heard clicking noice before she noticed it warming up. Any...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 20, 2011 | Refrigerators
2002northland 36" refridgerator and freezer not
The compressor should turn on after it cools. It shuts down if it overheats to prevent damage/fire. The compressor itself could be bad but more than likely the fan is dead.
Jan 11, 2011 | Northland 36SSS Side by Side Refrigerator
Bad ground some where
Hi:
There is a pressure switch on the side of the AC refridgerant reservoir area. If the switch is bad, or the level of refridgerant drops, the pressure switch doesn't allow the compressor to kick in. When you are running the wire from the relay to the compressor, you are bypassing the pressure switch. I am guessing that to fix your problem, you need to check the charge on the AC system, or check the pressure switch, and hopefully you will find your problem.!
Apr 29, 2010 | 1998 Lincoln Town Car
Refrigerator knocking noise
the motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
Nov 15, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
Feb 17, 2008 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerator makes lot of noise
based from your story. the noise could be coming from the compressor as it starts. compressor usually vibrates a lot when starting. it would last from a few seconds to a few minutes then would normalize as it sucked all the evaporator pressure down to its normal readings. you can check the rubber mountings of the compressor,you may need to replace them. also check for some tubings that may be rubbing or touching as the compressor vibrates. tighten alllso those mounting bolst of the compressor. that should solve your problem. if everything is done and still the same, the noise could be coming inside the compressor which there will be no solution but to replace the compressor. the cleaning that you did helped it a little bit because the vibration decreased a little coz it was able to breathe a little.
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
124 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
