Question about Humminbird GPS
I have a humminbird wide vision. When you push the power button, it comes on for around 30 seconds,shows visual power up on screen,then shuts down. light is on so unit power is ok. what the heck????????????
SOURCE: powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Posted on Jan 10, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: Help
Take every single cable out of the unit, now power on the unit.
If the power protection still shows then there is an internal fault, usually a short or a component defect.
If it powers on ok, switch off and insert 1 speaker at a time and power on the unit until the protection mode comes on again, the last speaker you have put in has overloaded it for some reason, also as you are trying each speaker use the volume and bass controls to see if there is an internal overload.
Thats as much as I can offer you until you narrow the fault down to the unit or one of the speakers.
Cheers
Posted on Jun 09, 2008
SOURCE: Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
SOURCE: power wont stay on
Hope your under warranty mate and if so hope its not in Australia as they cannot fix this problem. My denon was allegedly fixed twice but has now failed a third time (just out of warranty) and denon have turned their back on me.
SHAME ON YOU DENON.
Posted on Jul 19, 2008
SOURCE: Blank Screen
My gps unit shows that the unit is turned on but the screen is still blank. Could you please help.
Thanks Charissa
Posted on Aug 27, 2008
From black screen when push power and V+ button at same time, visual land screen shows, but will not go to next screen. How do I resolve this?
All I can possibly say is to hold the V+ and V- and Power at the same time, it is kinda tricky. hold it for a while then it should show an Android laying down. Wish I could be more helpful.
May 24, 2014 | Visual Land Prestige Pro 7G Android 4.1...
Kindle fire screen repair
Press and hold the power button for fifteen seconds or so. Does it turn off then? If so, press and hold the power button for a second or two. Does it start to reboot then? Does it work properly now?
May 26, 2013 | Amazon Kindle Fire HD
My samsung infuse will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 23, 2012 | Samsung Cell Phones
Phone need to be reboot
dear sir or madam to reboot your motorola droid all that you have to do is hold down the power button until a menu pops up, select power off and then select ok the phone will shut down then once the screen is black hold down the power button until the motorola logo appears on the screen release the power button. in about 30 seconds your phone will show the lock screen. good luck!
Aug 31, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I accidentally put my Compaq 6715 b laptop into hibernation. I don't know how I did it or how to bring it out of hibernation.
You need to hit the power button just the once to bring it back out of hibernation mode. It may take around 30 seconds until you hear your computer starting to boot back up and a little longer for the screen to come on.
Failing this, you can try a hard reboot by holding down the power button until you hear your computer re-boot. Usually you need to hold around 10 seconds. However using this last method as a final resort will result in your computer telling you that it did not shut down properly.
Aug 04, 2011 | Computers & Internet
I accidently shut my computer down with hibernation before leaving. When I come home, the computer will not turn on, no lights no noise, nothing. How do I unlock the hibernation? Or could it be something...
Jul 08, 2011 | Gateway 310X PC Desktop
How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
Welcome to Fixya.
Please try the following steps to resolve this problem - this same procedure worked for my colleague :
  • Power off printer
  • Hold down STOP/RESET button then Press and Hold down Power button
  • Keep Power button down and Release STOP/RESET button
  • Push STOP/RESET button twice
  • let go of power button
  • Wait 20-30 seconds - my display shows "canon Idle"
  • Then Push STOP/RESET button four times
  • Push Power button twice
  • Power off (shut printer down)
  • Wait for at least 5 seconds and power it back on
This should do the trick and will get you printing again in no time.
Thanks for using Fixya.
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
My computer turns on, the green light is on and the orange light is blinking but screen doesn't show anything
I may be in low-power mode. Try jiggling the mouse, pushing enter on the keyboard a couple times and just pushing the power button once.
If none of those work push and HOLD down the power button for about 10 seconds and the computer should shut off.
As an absolute last resort pull the power plug, leave it out a few seconds then plug it back in and power it on.
One of these methods should at least get the screen back up.
Jun 07, 2010 | Smart Modular SV3170A
Calling for a older friend> ac power outage happened within 30 secs of each other. Now computer comes on and begins startup showing screen but shuts down and starts up all over again and again
Unplug everything, wait a few seconds and retry startup. But it almost sounds like a virus or malware was uploaded into the computer. Also try startup in "Safe-Mode". Hold down key marked "F8" after pressing the power on button.
May 20, 2010 | Computers & Internet
GPS Logo
88 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
