Question about RCA RS2652 Shelf System
CD player will not read any disc
The Cd player just stopped reading discs. When I load them in the tray the player seems to try to read them then it displays NO DISC and tries the next one repeating the same cycle.
    Scholar:
  • 148 Answers
Try cleaning the lens, best way is to open it up and use rubbing alcohol (the purer, the better) with a q-tip. Wait for it to dry, then test it. If that doesn't work, you'll most likely need a new pickup. This might be of interest to you: http://www.repairfaq.org/sam/cdfaq.htm#cdlasdlife
Posted on Apr 21, 2006
Portable cd player DP-R4440
You are describing a common failure of this type of CD player
Aug 22, 2013 | Kenwood portable cd player DP-R4440 User...
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Cd/dvd stops reading disc half way then stops.loading tray sticks or has a delay
Disc stops playing due to tracking error from either a dirty source cd or a dirty blank. It is not the machines fault. Clean both discs thoroughly before recording. Even non visible dust can cause a stoppage. My Sony recorder does seem to be a little too sensitive to dust but it normally works fine.
Mar 09, 2010 | Audio Players & Recorders
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Jan 11, 2009 | NAD C521 CD Player
Ate my CD
looks like the tray is offline so basiclly its not reading the first disc because its far away from the eye so by putting another disc in and it reads it because the eye is close enough to read it .  u may have to open the player up to get the first disc out.  good luck.
Oct 24, 2007 | Pioneer DEH-P690UB CD Player
Stanton C500 Dual CD Player
hi, check that when the right side tray closes the screen must show up READ or DISC CHECK. the behaviour must be the same as the left side cd deck. if loading is faulty then the cd tray is out of alignment or sensing swithches are faulty. if disc is loading then u have a laser pickup problem or the laser ribbon cable is intermittent or the spindle motor is tired or the laser lens needs accurate cleaning. cheers.
Aug 05, 2007 | Stanton C.500 Dual CD Player
RCA RS2652 Shelf System Logo
168 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
