Question about Samsung Microwave Ovens
Entire microwave is dead except LED screen which has a message -- E 5 -- Spoke to Samsung who told me to unplug it for 10 minutes - that dosn't do anything. This is a top of the line over the stove model.
  • Samsung Master
  • 9,086 Answers
From the Samsung FAQ:
For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater (sic) to find your nearest Authorzied Service Center.
It may be a failed sensor.
Posted on Sep 16, 2008
Samsung microwave.....there is power and lights but no heat and timing is all screwed up, ie, moves thru 30 secs i9n 3 seconds!
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 15, 2013 | Samsung Microwave Ovens
Samsung microwave error messages
This is a sign the keypad has a shorted membrane.
Mar 16, 2012 | Samsung Microwave Ovens
Lost power last night - now Microwave won't work - control panel is not lit - unplugged for 10 seconds and replugged in - socket has power
Hi, W/D here.
Leave unplugged for a longer time, say 5 minutes. I have done this twice on my own, and it has worked, but it took about 5 minutes.
--W/D--
Feb 09, 2011 | Jenn-Air JMV8166BAS Microwave Oven
LCD pad, numbers do not appear clearly but as a distorted image. example 1:10 may appear as blank.1E example .40 may appear as blank.1L microwave works fine just the read out panel is distorted,...
On most recent Sharp microwaves, the fuse only interrupts main power, so if the fuse is blown, it will be totally dead.
If that doesn't work, leave it unplugged for about 5 minutes then try it.
Then chances are you have a failed microwave display. Unless this is an over the range, touch screen, or convection type, it's probably not worth repair, but you can get more information on such repairs here.
Jan 15, 2011 | Sharp R-310CW 1100 Watts Microwave Oven
I have a Samsung microwave in our travel trailer, and all of the sudden, the keypad reads to press 6, but none of the keypad buttons are working, and the message keeps scrolling on the readout display. I...
This is a microprocessor problem in the appliance. It can often be reset by unplugging the device, waiting 10 minutes and plugging it in again. If that doesn't work, you will probably have to replace the appliance (cost to buy a new one in usually a lot less than trying to get it repaired).
Oct 10, 2017 | Samsung 1.8 Cu. Ft. Over-the-Range...
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
Kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
2006 Frigidare Gallery Series 7G61704301 dosn t work
Did you have a power surge? Try unplugging the unit for 10 min and plug back in to reboot the curcuit board. If letters and numbers are being displayed it usually means the board is confused or fried.....
May 06, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Help
Try to unplug the micowave and let it stay unplugged for 10 -15 minutes. Plug it back in after 10-15 mins and see if it resets the error message.
Jan 25, 2008 | Microwave Ovens
Microwave Ovens Logo
555 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
