Question about Thermador Kitchen Ranges
Model SGSX365CS/02 The burner On light has come loose from its mount and fallen down into the body of the cook top. How can I get to the light to remount it?
I removed all the burners and then removed the top to get at the burner light. RepairClinic.com helped.
Posted on Sep 12, 2008
How do i change a whirlpool model wbp88800 burner control
Unplug stove. There should be two screws under edge of the cook top. You need to open oven door to get at them. Remove screws, lift cook top up at the front and prop it up. There will be two or three screws with spring clips holding the burner to the cook top. Unplug the connections, remove screws, remove burner. Install in reverse. I did this at Christmas just in time for dinner. It takes about ten minutes.
Feb 06, 2015 | Whirlpool Kitchen Ranges
GE Profile GSP40 cooktop hot burner indicator wont light up
This is obviously a loose connection in the panel that is flexed when you put pressure on the top. The rear panel needs to be opened and checked.
Jan 22, 2013 | Cameras
All ignitors not igniting on model # sgsx365cs, 5 burner cooktop.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 19, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Hot indicator surface light will not turn off on maytag smooth top oven cre9600bce. always stays red even when oven or cook top not in use. What part is needed.
I had the same problem, but I found out it was only when one particular burner was turned on. I waited for the problem burner to cool, then took the fist of my hand and tapped on the burner itself and the light goes out every time. Works like a charm..probably a loose connection with that one burner.
Jan 30, 2010 | Kitchen Ranges
Kitchen aid KECC507GBL3 electric 36in cooktop. Burner switch is out - cannot get glass top off. Have removed all screws from plate mountings on the sides. Is there a trick to this?
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Jan 14, 2010 | KitchenAid Cooktops
Tappan stove model # 30-3053-23-02. How do I remove the stove top?
For Tappan stove model 30-3053-23-02.
Each burner (4) is mounted to the stove top with three 4.5mm hex screws. All 12 screws must be removed, which is easier said than done. In my case, of the 12, 6 heads snapped off. The other 6 heads had to be drilled out. The metal is very hard (tempered from long exposure to high heat?), so use a carbide/diamond high-speed drill bit (1/8" or 3/16").
The front corners of the stove top are each held by a clip. After removal of the burner mount screws (or heads at least), lift straight up on each front corner of the stove top to release the top from the clip. An alternate method is to use a screwdriver as a lever to pry the corner off the clip. Once released from the clips, the front pulls up, while the back is "hinged" (like lifting an auto hood). Using a stubby phillips screwdriver, unscrew one of the back hinges. At this point, the stove top can be lifted off.
If you are fortunate, the burners were unmounted by simply removing the screws. But if they broke off or had to be drilled out, it seems the best thing to do is just purchase new burner assemblies ($20-$30 each). In either case, also buy new screws specifically for mounting the burners.
Dec 22, 2009 | Kitchen Ranges
Stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
Aug 02, 2009 | Kitchen Ranges
Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
May 27, 2009 | Roper FGP300 Gas Kitchen Range
Kitchen Ranges Logo
127 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
