Question about Navman GPS
Switches on to initial screen but will not progress futher.
  • 435 Answers
First, try to update your device........
Revert back....
Posted on Sep 11, 2008
    Master:
  • 726 Answers
Needs a update from your pc it will do that if the device thinks its out of date it did it to mine
How do I remove the door panel on my 2014 jeep patriot
pull from bottom , and it goes pop.
then take off all things that prevent futher progress.
Mar 14, 2015 | 2014 Jeep Patriot
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
Rio Forge gets stuck on boot up after changing files
In this case, it turned out there was an m3u file on both the memory card as well as in the internal memory with the same filename. I deleted the duplicate file on the memory card and it booted up fine. I assume I could have renamed it instead of deleted it and still had it work.
Jun 13, 2009 | Rio Forge Sport Digital Media Player
Progressive/interlaced image problem
In the Initial Settings Menu go to Component Out, ther you can switch it.
May 16, 2009 | Pioneer DV-300-K Player
Thin black horizontal line across the middle of the screen
It looks like you've got problems with your screen. If that one is on a warranty, replace it
Jan 22, 2018 | Westinghouse W32701 27 in. LCD HDTV
Progressive scan mode will not go away.
Depending on the model or version, normally Progressive Scan Mode maybe enabled/disabled by:
  • PScan or PS button on the original remote or front control panel;
  • a slide switch at the rear.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Zenith XBV443 DVD Player/VCR
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
GPS Logo
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
