Question about Numark BATTLE PAK v.4 Turntable
When i turn my turntable on,they is a slight dip and rise in the platter is this normal.if not what should i do to mend it.
Is the platter itself moving up and down or the record? It could just be the record's wear and tear (warped) which raises the tone-arm which in turn makes it move up and down on certain sections of the record. Try bending the record (very very slightly) to straighten it out or put more weight on the tonearm.
Posted on Dec 17, 2008
I just got this turntable, and the platter has a wobble.
First check that the adjusting screws that stop the turntable moving about during transport are fully open.
Lift the turntable matt and move the platter by hand. You should be able to see that everything is OK or anything that looks odd. If you still can't see anything wrong remove the platter. First make a note of the belt fits. Take photo's if it looks complicated.
The platter will be fixed from the spindle. It might have a horseshoe clip holding it. They are tricky to get off, but try. If the spindle has a cover, remove it. If it is glued you can force it off. You can re-glue with Bostick later.
Examine the platter to see if it is bent!
Dec 21, 2015 | Audio Players & Recorders
The platter on technics sl m2 looks to dip when turning
All I can suggest is that you remove the turntable mat and platter and see if there is something that might cause the problem. If you still can't see anything remove the 4 screws this will give you access to the direct drive motor. Again a visual inspection might help find the solution.
The service manual is on line, but there is nothing specific about your problem in it. But you can see what the parts should look like.
http://elektrotanya.com/technics_sl-m2_sm.pdf/download.html
Sep 03, 2015 | Technics Audio Players & Recorders
I have Aiwa LX-D10 the arm will not travel or rise or lower, Can you help
Does the platter on the turntable turn? You should be able to make it swing out by hand operation of turning the platter.
If you can do that it's likely that the belt to the turntable is slack and needs replacement.
Nov 12, 2014 | Audio Players & Recorders
Stanton str8-20 belt size???
HI,
If you are unable to find your turntable measure the nearest length, if you are unable to find the exact length (as belts stretch slightly with use and age) choose the nearest shorter length. To check drive belt length for most type full platter decks remove mat and lift platter off center spindle (remove circlip if fitted), turn platter over and measure the circumference of the drive hub and deduct 5-10mm to determine correct length and tension
OK
Dec 11, 2012 | Audio Players & Recorders
Zennox usb turntable arm rises before end of record
Hi, we don't have that model turntable in NZ so I can't say exactly where the adjustment for the tone arm lift position is. However on the majority of turntables it will either be beside the base of the tonearm possibly under a rubber grommet or if you remove the rubber platter mat and there is a hole in the platter near the outer edge rotate the platter whilst looking through the hole for a screw near the tonearm. Adjust anti clockwise a little and test. Fine tune until you are happy with where it stops. John. styluscity.com
Nov 24, 2011 | Audio Players & Recorders
Hi,my vestax 2300 platter has a slight wobble.i removed the platter and it seems 2 b the motor,can u help?
sliight wobble is normal but if its something you notice i suggest sending it to them to fix it
Apr 28, 2011 | Vestax PDX-2300 Turntable
Numark tt200 motor
The knocking sound is NOT normal, and you should not ignore it.
The tt200 is a HIGH TORQUE turntable, and as such is a highly accurate lathe for the accurately determined speed of the platter.
The lathe is in need of adjustment, which is recommended.
Apr 06, 2009 | Numark TT200 Turntable
Pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Jan 10, 2009 | Pioneer PL-990 Turntable
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
Numark BATTLE PAK v.4 Turntable Logo
114 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
