Question about Epson Office Equipment & Supplies
Instal cartridges/new set-up epson S20 - Epson Office Equipment & Supplies
    Master:
  • 397 Answers
Here is a link to the download site for the SetUp and full User Instructions for your printer:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=Yc2M45mBlTYt1Z7WU002FVpqZmDDu85W1oPi&tc=5
I just checked and the User Instructions have detailed instructions on how to change your cartridges.
Posted on Sep 11, 2008
    Genius:
  • 1,239 Answers
Move your cartridges to the left removal position by pushing the orange button (890/1280) or hold the paper feed button in (older printers). When the cartridges arrive at the removal position, PULL THE POWER PLUG FOR THE PRINTER OUT OF THE WALL AND DISCONNECT THE INTERFACE CABLE (USB OR PARALLEL).
Remove the cartridges and then continue with step 2.
The power must be disconnected so that any corrupt data stored in the printer does not get written to the new chips causing them to fail prematurely.
To get chip off. Use a single sided razor blade and remove excess plastic from the top post holding the chip in place. Don't touch the bottom post. (On a new virgin empty cartridge that has never had a chip on it, this step is not necessary.) Use a knife blade or thin screw driver blade to pry chip off of cartridge. instal cartridges/new set-up epson S20 - topmenu8.jpg
 hi sir here is the solution : 1.   Move your cartridges to the left removal position by pushing the orange button (890/1280) or hold the paper feed button in (older printers). When the cartridges arrive at the removal position,PULL THE POWER PLUG FOR THE PRINTER OUT OF THE WALL AND DISCONNECT THE INTERFACE CABLE (USB OR PARALLEL).
  2.   To get chip off. Use a single sided razor blade and remove excess plastic from the top post holding the chip in place. Don't touch the bottom post. (On a new virgin empty cartridge that has never had a chip on it, this step is not necessary.)   3.   Use a knife blade or thin screw driver blade to pry chip off of cartridge.   4.   Slide new chip on to lower post. Don't try to force it over the excess plastic on the lower post. Take advantage of the U channel in the chip. When it is captured, then press the chip onto the top post.   5.   If the chip is loose, remove it and then use a SMALL amount of super glue or equivalent on the back side of the chip to keep it in place. CAUTION... do not get any glue on the gold pads. If the chip snapped in place you will not need any glue.   6.   Re-install the cartridges in the printer. Slide the cartridges back to the far right by hand. ThenTURN ON THE PRINTER POWER and reconnect the interface cable.   WARNING:    DO NOT PUT A CARTRIDGE WITHOUT A CHIP ON IT INTO THE PRINTER - IT WILL CAUSE FATAL DAMAGE TO PRINTER !!!If you insert a cartridge that does not have a chip on it down into the cartridge holder, the small metal fingers that normally make contact with the chip will get caught inside the cavity for the chip. Then when you pull the cartridge out, these fingers will get bent and the printer will be ruined.DON'T DO THIS !! The symptoms of this being done, is a constant red light on the printer regardless of the chip condition. The contact fingers never touch the chip again.
    Master:
  • 726 Answers
U have to open the machine and the old cartridge pop out then clean the terminals put the new cartridges in and close the lid if there all the way to one side slowly move them a cross
SX200 WILL NOT RECOGNISE NON STD INKS
Check your update settings in the printer software. Turn off any automatic updates from Epson. To get updates, put some old Epson cartridges, good or bad, in while you update. Epson will log on to your printer and kill your non-Epson cartridges during auto updates.
Apr 09, 2015 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epsom sx100 keeps saying cartridges are not compatatble but are using epsom inks
If you have Genuine Epson cartridges and they do not work, call Epson Tech Support. You have to be patient [they're in India] and you may have to ask to speak to someone in the US if you're getting nowhere with TS.
Oct 06, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson s20 cannot recognize ink cartridges
have you bought genuine ink cartridge?? if it isnt genuine or original the printer wont recognize it at all..
Jun 02, 2010 | Epson Stylus S20 InkJet Photo Printer...
My epson stylus s20 printer wont recognise genuine ink cartridge
If you are having issues printing, this could be caused from your printhead needing to be replaced.
May 31, 2010 | Epson Stylus S20 InkJet Photo Printer...
Epson S20
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 21, 2010 | Office Equipment & Supplies
Epson stylus s20 problem. Printer will not print if just one of the four colour cartridge is empty. Can the printer be programed to print with what cartridges are avalible? The printer message does not say...
Unfortunately, all cartridges must be used in unison. In order to print one color you can usually go into your settings and set it to black and white only, but some models will not even do this. To be frank, these Epson models have a horrific reputation on the Internet for not recognizing cartridges, only printing 10's of pages before the ink runs out, and just general overall problems. I am sorry, but I would professionally suggest buying the cheapest Kodak/HP/Brother at Wal-Mart over even trying to troubleshoot this model at all.
Oct 22, 2009 | Epson Stylus S20 InkJet Photo Printer...
EPSON Stylus S20 print cartridges not recognised.
Try reinstalling cartridges make sure you remove the yellow strip.Ok turn your printer off and back on while installing cartridges ,if this dosen't work disconnect printer cable then turn printer on then off reconnect cable turn on again also disconnect power to printer then reconnect if all fails call Epson and your warranty may cover this
Aug 27, 2009 | Epson Stylus S20 InkJet Photo Printer...
Epson S20 does not recognise cartridges
It should be returned to the seller for exchange under warranty.
I presume you have removed the tags on the cartridge and ensured they have chips on the cartridge case? If all that has been done then i would be making a warranty claim
Jun 21, 2009 | Epson Stylus S20 InkJet Photo Printer...
Epson s20 genuin ink not recognised
I think the problem is in your windows, try to reinstall your windows. I suggest, don't reset the original chip, cause it's damage the chip.
May 29, 2009 | Epson Stylus S20 InkJet Photo Printer...
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
