Question about Insignia I-PD720 Portable DVD Player
Picture I can hear the DVD fine it is just the picture that keeps flickering and skipping.
  • BABETTEL Apr 21, 2008
    The sound is perfectly fine, but the picture flickers and jumps constantly.
  • Anonymous Dec 23, 2008
    I have the exact same issue. the flicker appears to be going back a forth from the current scene to the previous scene change. Could it be a buffer issue?
    Novelist:
  • 130 Answers
What does it do when you hook up a powerpack? i understand its suposed to be portable but the DC voltage may not supply enough to keep it a constant. Could be a bad ground or its picking up some static in the air.
Posted on Apr 21, 2006
    Scholar:
  • 148 Answers
Two possibilities: 1)The pickup or 2)the LCD Screen and its counterparts. By your description, I can't tell for sure. Is it like someone is turning the screen on and off, or does the sound actually get misaligned with the picture? In your case, it probably wouldn't be worth the repair for either as parts for this particular unit cost 80$(US) and up. If it's the screen itself, you're looking at a 200-400$(US) repair.
VHS won't display any picture but audio works???
how do you have it hooked up? there are different connections for the dvd and vhs sides of the player
May 20, 2014 | Panasonic PVD4744 DVD Player/VCR
When i put a disc in and play it the picture keeps shutting off and then coming back on......skipping on/ off on/off on/off
The problem with you DVD, is that the lens needs to be replace. The skipping and stopping of the picture is as a result of a faulty lens. the distortion of picture is the symptoms of bad lens.
Jun 03, 2010 | Sony DVP-NS300 DVD Player
I have an XDVD271 and the picture flickering or skipping. The audio is fine. What is going on?
Try to check/toggle the int - ext A/V switch on the left hand side of the unit, that might solve it if it is only on one screen, if it is on both it is most likely the DVD player itself, try with a clean good DVD to check if it could be a dirty or scratched DVD.
Feb 15, 2010 | Dual XDVD270 Car DVD Player
Picture flickers on and off. just had a power
need a manual for magnavox - video cassette recorder/dvd player
model # mvd540vr/17
Nov 01, 2009 | Sony KDS-60A2000 60" HDTV
Why does the picture flickers,keeps moving down but clear sound
yes this is a simple fix,change the tv channel up 1 or down 1
Aug 05, 2009 | Panasonic SC-HT920 System
My dvd is in the progressive scan mode
Refer to the problems and solutions list...we had the same problem and following their steps resolved it!
Aug 29, 2008 | Zenith XBV442 DVD Player/VCR
Video keeps flickering
TRY SWITCHING VIDEO SYSTEM. PAL TO NTSC.
Jan 30, 2008 | Farenheit DVD-36 Car DVD Player
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Hitachi skips over commercials & flickers
If by saying the "aspect ratio changes" you mean the picture shrinks from top and bottom, I would suspect an intermittent short inside one of your picture tubes. The commercial skip function is not causing a problem here. It is the rapid change from dark to light that I believe is putting an extra strain on a weak or defective picture tube.
Jan 18, 2007 | Hitachi 43FDX01B TV
Insignia I-PD720 Portable DVD Player Logo
123 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
