Thomson TG 585 v7 Wireless Problem
I've thomson tg 585 v7 router, but wireless doesn't work at all. on router all lights are green (including Internet and Wireless), in router's management panel i see that everything is ok, when checking internet connectivity it shows that it is. my laptops (windows xp and windows vista) is showing that there's no connection to internet. windows xp in wireless connections is always showing "acquiring network address", windows vista shows that are connected to router and address is acquired. but there's no f.. internet. router sees both computers on the network. ant ideas?
  • ScotInWales Feb 18, 2009
    After months of working fine my wireless router keeps losing its connection with my laptop. Sometimes the router does not appear as an option for connection. All the lights on the router are green but still can't conect. Sometimes the connection works and then disaears all together. Totally confussed. I have tried lots of different things and tiscali won't help. Does anyone have a solution?
  • 6 Answers
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Posted on Sep 11, 2008
I had the same issue, about three hours after having a Tiscali engineer install my Thomson 585 suddenly the wireless disappeared. After checking everything I could think of on the router via the menu ( see the IP address in Solution 2) nothing fixed it, Last resort I tried changing the wireless channel from 1 to 11 and hey presto its working again! Don't ask me why but this seems to have worked for me.
Posted on Dec 04, 2009
The problem is not with your pc's. It has to do with your ISP.
Once connected to my modem (http:/192.168.1.254) my ISP Technical Support had me run the "Set up" task in the Thomson Gateway menu.
Once in the set up configuration they had me change the network segment from a drop down list. They also provided me with a new username and password to maintain a persisten connection. Unfortunately this isn't something you can do on your own. It seems it's ISP specific so you'll need their assistance.
So far so good with my modem.
Hope this helps.
Posted on Aug 12, 2009
Nothing wrong , problem wifi not communicating , switch of the modem for a while and switch on then wifi will work
Posted on Apr 24, 2010
Yo tengo un problema y por eso le pido su cobolaracion mi internet se cae cada 5 minutos por eso yo les pido que que me dejen a mensaje en mi correo es estefanelldeford_251@hotmail.com
Posted on Oct 23, 2008
I have a problem all lights are on, it says it's connected but when I try a web page it says the dsl line is down but it works other times is there something unplugging and plugging or is there a different problem
Posted on Sep 03, 2011
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
Thomson 585 v6 we're is the wps button.
Hello:
According to the manual, the Thomson ST585v6 doesn't support WPS. You will have to record the wireless passphrase and enter it manually in the device you're trying to install on the network.
Manual: http://downloads.thomson.net/telecom/documentation/ST585v6/R82X/SetupUserGuide/PDF/ST585-v6_SetupUserGuide_en.pdf
Mar 12, 2014 | Arris SURFboard SBG900 Wireless Router...
Barq wireless
CALL THE COMPANY OF THE ROUTER OR THE PROVIDER OF YOUR INTERNET
Jan 31, 2014 | Thomson Be Broadband TG585 v7 SpeedTouch...
I try to acces my router options and it asks me for username and password, ive tried all the default usernames/passwords but it still doesnt allows me to enter, ive even tried on different computers,...
Look on the back or bottom for a reset switch. Usually it is recessed and you need a tip of a pen or paperclip to push it.
Hold it down for about 10 seconds.. Then power off and on. This should set it to factory settings, and you should then be able to use default login and password.
Dec 01, 2010 | Computers & Internet
How do i change the channels from 1 to 11 on my router thomson tg 585v7
This setting is changed by accessing the router directly. Typically you have to plug network cable into the router directly, access via web browser, and look under wireless settings.
Remember to change system ID to something you would recognize, set access password for the router, and turn on wireless security. LOG ALL passwords.
The channel issue change to 11 is a good idea as many routers compete with wireless home phones for the lower channel numbers, but suffer intermittent failure, not complete malfunction. Good on you for desiring to change to 11 (or so).
Oct 03, 2010 | Computers & Internet
Need driver thomson tg 585 v7
visit free download ptf.com/thomson/thomson+tg+585+v7+free+driver -
Feb 15, 2010 | Computers & Internet
Thomson tg 585 wireless multi user adsl2 GATEWAY
Hi, Did you manage to solve this. I have a similar problem. My thought would be to add belkinf5d7132 as range extender, but not sure if this works with thomson tg585. Regards
Dec 10, 2009 | Belkin (F5D7132) 802.11b/g Wireless Access...
I need to download a modem for thomson tg
Dear,
This is the location
http://www.thomson.net/GlobalEnglish/customer-service/SpeedTouchDocuments/xDSLGA-Wireless_Firmware_UK_gen_TG585_en_7-4-4-7.zip
Oct 17, 2009 | Computers & Internet
Lost connection
what u need to do is go to the interface of ur thomson speed touch through writing the ip address of that modem on the address bar of ur internet browser then go in that setup....Choose router instead of bridge.
Jul 14, 2009 | Computers & Internet
Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
27,713 people viewed this question
David Payne
David Payne
