-   having the same Problem.
Please describe the specifics of your problem below. We'll add your post as a comment to sarma's "canon ip 1000 waste ink reset" problem,
-   dasbijoy04
Mar 06, 2009
-   yes the same Problem.
Please describe the specifics of your problem below. We'll add your post as a comment to sarma's "canon ip 1000 waste ink reset" problem, and notify you when a new solution is offered.
-   Guest
Mar 06, 2009
-   yes i have the same Problem.
-   Guest
Jan 29, 2009
-   My waste ink absorber is full. I wondered if I could fix it. Canon says a technician has to do it, but there are none anywhere near me.-   Guest
Aug 19, 2008
-   al tratar de imprimir cualquier documento presenta el siguiente: mensaje ¡el deposito de tinta excedente esta lleno llame al servico tecnico para cambiarlo!.
ya se limpio el deposito y aun continua presentandose dicho mensaje.-   Guest
4 step to Reset waste ink tank counter CANON PIXMA iP 1000 STEP 1:- Disconnect printer from AC power STEP 2:- Press and HOLD the POWER button, and connect printer to AC power STEP 3:- release the the POWER button STEP 4:- Press the POWER button again
Instructions Things You’ll Need: Gloves Step 1: Open the top of the Canon Pixma ip1000 and look inside. Step 2: Locate the waste ink absorber pads. These are at the bottom right inside your printer. Step 3: Put on the gloves. Now remove the waste ink absorber pads and holder from the printer by gently lifting them out. It feels like they snap out, so do not be afraid to tug gently to remove them. Step 4: Clean the waste ink absorber by soaking up the ink with a tissue or wipe. Set the waste ink absorber on some newspaper to avoid ink spills. Step 5: Go back to the Canon printer, and view the other waste ink absorber. This is also on the right-hand bottom in the back of the printer. This one has screws to remove and comes out with a plastic piece. Step 6: Wash the sponge with clear water. Allow it to dry completely. This may take at least a day. When it is completely dry, reassemble. Step 7: Replace the waste ink absorber pads and sponge. Connect the printer to the power source.
Keep getting a message say either the front panel is not closed or the cartridge is not installed....
(More)
Keep getting a message say either the front panel is not closed or the cartridge is not installed. Have checked each but meaase still continues
my printer is all of a sudden not printing and the control panel indicates that it is offline. How...
(More)
my printer is all of a sudden not printing and the control panel indicates that it is offline. How do I get it back online?
at first a blank line rean down the page from top to bottom. Now when printing the page is blank or...
(More)
at first a blank line rean down the page from top to bottom. Now when printing the page is blank or white.
