Question about Sanyo DS20930 20" TV
Ds20930 received this tv from father in law with no sound, but excellent picture quality. followed manual troubleshooting tips with no success and called Sanyo service tech and they said cheaper to buy a new tv than possibly fix. Any suggestions????
  • jph611 Sep 23, 2008
    Thanks for the advice. I took the back off the tv and found a loose wire. It is working now. Thanks again.
    Scholar:
  • 188 Answers
Try resetting the settings. In the menu there should be a settings option. Reset them to default of facory settings. Here is a website that mayl help you with this.
Let me know if this works out for you.
http://www.retrevo.com/support/Sanyo-DS20930-TVs-manual/id/17567dj485/t/2/
Posted on Sep 22, 2008
HELP! Surround speakers not working with 5.1 material.
This may sound silly, but . have you checked your sytem setup settings to make sure it is set to 5.1 ,if so then you may very well have a bad channel
Mar 29, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
HOW CAN I FIND THE CLOSED CAPTION ON SANYO TV MODEL DS20930
User manual:
See page 6 (CAPTION button on the remote) and page 14 on how to use Closed Caption functions.
Dec 30, 2010 | Sanyo DS20930 20" TV
Sound is not working. everything is plugged in right. got the tv from my father-in-law who always had it hooked up to a receiver box. now we have it and dont have a receiver box and are unable to get any...
it sounds like the internal speakers are just off. you should be able to navigate the menu and find where to turn the speakers back on. i have my tv set up with a surround sound system and turned the internal tv speakers off. should be in the sound settings or with a picturre of a speaker.
Dec 24, 2010 | Pioneer PDP-507XD 50 in. Plasma Television
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
TV picture size (height) adjustment
TV model # PCJ 612 R SAMSONG SERIAL # 39Z 300 125 W
Dec 06, 2008 | Televison & Video
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
I have a pioneer elite plasma (Pro-1540HD),and my color settings are completely screwed up.(my kids and father-in-law were messing around with my remote.). I've gone through the manual and done everyhting...
Start with page 51 in the manual, disconnect all external sources(vcr,dvr,cable box,etc.) start the tv with just the cable from the wall jack straight to the tv. make adjustments as needed.when you have a satisfactory picture, reconnect the external sources one at a time and see if the picture changes after the addition of each component, if it does, the problem is probably that component. good luck.
Marc
Sep 13, 2008 | Pioneer Televison & Video
Sanyo tv ds20930
Does your screen light up or picture comes before it turns off? This could be from your X-ray protection feature, you will have to check the power supply output voltages.
Jan 30, 2008 | Sanyo DS20930 20" TV
TV Volume goes up when channel is changed Philips 20S240
I don't think the IR sensor has anything to do with it. It sounds like a surface mount micro processor to me...
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
DS20930 TV
Sanyo makes a fine TV. You have a problem in the vertical circuit causing the line. You should not play the set in that condition because you can dammage the picture tube. Call a few local shops to get an idea of what they charge to fix a vertical problem on a 20" TV. If the cost of repair exceeds about 65% of replacement, toss it. In my opinion the newer sets are lacking in quality compared to older ones. In short , they break more often. If you choose to buy a new TV stay with a known Japanese brand.
Nov 29, 2007 | Sanyo DS20930 20" TV
Sanyo DS20930 20" TV Logo
288 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
