Question about Kenwood KDC-4007
Wire harness I bought a receiver through e-bay and the only thing sticking out the back was the female connection for the antenna. Do you sell or know where I can get the female wire harness for this receiver? Thanks,Stan
    President:
  • 3,130 Answers
You can go to this site for all your car audio install needs http://www.tune-town.com/
Posted on Apr 20, 2006
SOURCE:
Which cord is the antenna on eclipse cd receiver model 8443
It will be the black cord with a female
connection half inch hole, or there will be
a small half ince hole in the back of unit
where the antenna wire will plug inn
Jun 16, 2014 | Eclipse CD2000 CD Player
Can I buy a VR500CSBT connecter to female ISO connecter to fit VR500CSBT in my Vauxhall Corsa as I don't want to cut the indvidual wires of the conecter that came with the stereo and join it to an
they sell wiring harnesses that connect to the car manufacturers radio/player harness with wires to connect to after market players, do they sell one for your car? not sure
Mar 10, 2013 | Roadmaster (VR500CSBT)
I lost the manual to install my stereo pioneer DEH - 23ub
go to store that sells car decks and look for a wiring harness for ur car its about $7 mybe and prettymuch match the colors on ur deck to the harness and then pull ur old deck out and pull the harness from the back the back of that deck and plug that into the wire harness u just bought and hook up the antenna for radio andput the deck into the dash the wire harness should also come with so directions too just in case
Apr 16, 2011 | Pioneer DEH-P2900MP CD Receiver...
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
I have a pioneer DEH 525-W car sterio harness and colors do not match to that of the Saturn L2 1999. How do I connect this car sterio?
Just go to Best Buy and buy the Saturn L2 1999 Harness . then it will match. Harness cost like 20 bucks.
1st STEP
Things to get from BEST BUYor RADIO SHACK.
1. Black electrical tape
2. (Optional) for quality connection Solder & Solder gun
3. GM (General Motors) Antenna Adapters
4. GM 1999 Car Harness
5. GM Saturn L2 1999 Car Kit
STEP 2 = Match the colors of the car harness you just bought to the harness of the radio (DONT PLUG IT INTO THE CAR YET CAUSE YOU MAY SHORT OUT THE POWER WIRE TO GROUND) twist the same color wires together and then tape them so it wont be exposed to get shorted out and damage your radio or blow fuses in the car.
STEP 3= plug in the complete harness to the radio and the car and also plug in the Antenna adapter to the small antenna jack of the car that converts it to a larger jack so you can plug it in the back of the new pioneer radio that has a larger antenna hole. Now test the radio it should work unless you had blown your radio fuse in the car already which is easy to replace.
STEP 4 Unplug everything from the radio and install your CAR KIT. Then slide your radio sleeve in the rectangular hole all the way flush and use a flat head screw driver and bend the tabs of the sleeve(Radio Cage) so that the sleeve wont move.
STEP 5 make sure your harness & antenna is sticking out of the sleeve so you dont have to fish it out later when you have finished mounting the car kit to your car. Put your car dash back together and you will see only a rectangular hole with a harness and antenna adapter sticking out only.
STEP 6 plug in the harness and antenna back into the radio and slide it in halfway only and test the radio again making sure everything works. If it does then move it all the way in till it locks into place. last snap in the face trim ring into place to cover the silver cage lining.
THERE YOU ARE FINISHED
Apr 09, 2010 | Car Audio & Video
I need to know witch wires go into witch hole on a vrcd400-sdu head unit there is 16 holes total on the back of the wiring harness
you don't stick wires in the holes. they make a male harness for the female harness you're messing with. your radio should have a harness that plugs into it with wires connected to it. then you buy the install harness for your year, make, and model car along with a dash kit if needed. then you proceed to connect the color coded wires from the head unit harness to the install harness you bought WITH CRIMP CONNECTORS. not packing tape or shrink wrap or any other thing you can think of to insulate the bare wires. crimp caps or **** connectors with electrical tape works fine.
Mar 17, 2010 | Car Audio & Video
Instalation tips, no manual with used fan
Hi, The bracket is like a cup with the downrod fitting into in with a ball and socket type arrangement. When the downrod ball is in the socket there is enough room to slide the receiver in, fold the antenna over the receiver when you put it in. It does not need to stick out. The whole thing is covered with the bracket cover and nothing shows. Good Luck, this should Fixya!
Mar 25, 2009 | Universal Remote Control Hampton Bay...
Sea worthy marine cd player sea 2300 + esp
Need help finding parts for a marine radio I bought at a rummage sale, It is a Sea Worthy,Sea9504 AM/FM cd player. Just have the radio,need wiring harness, and a antenna .Don't know what else i need? Don't want to buy another one. Have speakers to. Besides E-Bay taking a chance that the parts might work. Went to sites on the internet.Do you know where i can get these parts cheap,If you could help me.looking to purchurse by check not by credit card.
Oct 06, 2008 | Sea Worthy 9001G Marine Casseiver...
Remote receiver doesn't fit
ok since you have the power off move ceiling fan box electrical box over place remote above the electrical box with the antenna sticking out replace fan power up you might have to go into attic to place the remote sensor and antenna down to outside of fan i had the same problem myself i made a cut in drywall ceiling big enough for sensor unit let the antenna hang out placed up there
i used a wall plate cut in half to match the hole i just made or you dry wall back up but if remote goes out theres now no way to get to sensor unit
little cut in drywall place sensor threw antenna hang down put plate over hole
May 26, 2008 | Hampton Bay 24002 Ceiling Fan
Car Audio & Video Logo
53 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
