Question about Matfer 660 Watts 210412 Hand Mixer
Can you buy spare parts for a wahl hand mixer (james martin collection)ZX410/ZX410X. I have worn down the nylon cogs that turn the blades. Thankyou
I need a mixer blade for Andrew James hand mixer
Fixya does not sell replacement mixer blades.
Jul 29, 2017 | Food Mixers
My Sunbeam mixmaster quit spinning on bottom where the bowl sits
Does the bowl table rotate freely by hand? If not, it may need a squirt of spray lubricant. If the table rotates freely by hand but doesn't turn when mixing, look at the bottom of your beaters. The beater that is closer to the outside should have a nylon button at the bottom. This nylon button rotates the bowl as it turns. If the button is worn or missing, you will need to get new beaters.
Aug 18, 2016 | Sunbeam Food Mixers
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Teeth on plastic gears for mixer are worn down
Even if you could obtain the parts, a 10 year old mixer is well past its prime.
Jan 17, 2018 | GE 106772 HandStand Mixer
My K455 mixer seems to have locked up. The motor comes on but it will not turn the mixer.
check and see that the blades are install properly that can cause your problem..if parts are worn out then you need to buy a new mixer.good luck.
Sep 13, 2011 | KitchenAid 32685 Mixer
Hello, I have a Braun multimix 220 watt, and just recently it has stopped working. The blades turn but when I try to use them to chop (eg onions, mango) they get stuck and the motor just makes a whirring...
It sounds like to scnearios are likely; First, the gears inside the mixer can brake if overloaded, and secondly the motor may be damaged. If the motor is damaged, it usually makes extra noise when running, sparks may fly, and overheating and burnt smell can be observed. If not it is probably a broken gear or two. The gears for this mixer can be obtained as a kit containing all the nylon gears and they are quite reasonably priced. You will need to open up the mixer by splitting the two halves. Spare parts can be found either from your local supplier, from braun.com online or any other online supplier of parts. Please see this link for information on how to open it up to access the gears.
http://www.fixya.com/support/t3875766-braun_multimix_280_will_only_operate
Apr 30, 2011 | Braun M880 Multimix Hand White Mixer
I need a chopper attachment for my Braun M880 multimix hand mixer
See
http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
For a chopper attachment; you may need bowl plus rotating blade.
You may also use braun's own spare parts finder at:
http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
Sep 01, 2010 | Braun M880 MultiMix Hand Mixer
Blade will not turn
motor will hum but no blade turn if bottom seal worn and material leaks into shaft. Rekove drive head and try turning shaft if nio go dissasemble entire unit ,clean and service, replace seals
Sep 20, 2009 | Robot Coupe MP600 750 Watts Hand Mixer
My west bend hand mixer (model # 41015) blades do not turn
your unit is not worth repairing parts will be very hard to get this unit is usally a throw away unit
Dec 10, 2008 | West Bend 41036 Mixer
Mixer stuck
It sounds like you burnt the motor out or shorted the speed control.
Dec 24, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Matfer 660 Watts 210412 Hand Mixer Logo
119 people viewed this question
Top Matfer Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Matfer Food Mixer Expert? Answer questions, earn points and help others
