Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulon Wildthing 18" Gas Chain Saw
Machine starts and runs well but after a minute or two of running full speed it slows to half throttle. Its not the load, it runs at half throttle when I pull it out. A few pumps on the trigger and it comes back to full speed, but soon slows down again. Seems like its running out of fuel. Any suggestions would be appreciated. **** B
  • 3 more comments
  • DickScroggs Sep 21, 2008
    Wild Thing boogs down after running a high speed for a minute or two. Acts the same even without load. Do not have information on the adjustment of H and L carb adjusts that I think is the problem
  • Anonymous Oct 04, 2008
    the same thing happens with mine
  • cavemedic Oct 06, 2008
    My Poulan  starts like new, runs fine at idle,  skips a little when reving then revs up and runs fine at high speed.  Touch a log with the chair however, and it stalls right out.
    Can't find a vent hole in the fuel cap.  Anyone know how Poulan vents the tank?  Its a Poulan 295
  • waltnvon Nov 26, 2008
    On my Poulon Wild Thing, fuel is getting to the carb and the primer pumps fuel OK, but the fuel never gets from carburetor inlet to the intake port of the cylinder. I get spark on end of cable and at the plug electrode, but it won't start and the spark plug stays dry with no smell of gas in cylinder even after prolonged starting attempts at full choke. Compression test says 55 psi, and I feel slight suction at the intake port with carb off. Disassembled and cleaned carb thoroughly and that did NOT help. It wont even start spraying starter fluid into the carb throat. Any ideas?????
  • cavemedic May 11, 2010
    No duckbill in the fuel cap and it has never been replaced.  I bought the saw new.  My  son was using it while I was out of town and he says it was running fine, then all of a sudden, it developed this problem.  I am still thinking it is not venting.  Any ideas on what else could cause the problem?
    Problem Solver:
  • 9 Answers
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
Posted on Oct 26, 2008
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a 42 cc 18" poulan chain saw I cant get it to idle its either all or nothing. I cant start if the chain break is on and when it starts the chain runs. It dies under stress and then is a...
If the chain runs at idle, or tries to turn when cranking the saw, then there is an issue with either the clutch drum bearing or the clutch spring has become weak, to get to both of these components you need special tools, the tool to remove the clutch is part no. 530031112, and the tool to adjust the carb screws is part no. 530035560, the L screw will adjust from idle to half throttle including acceleration, the H screw will adjust the full engine speed
Apr 03, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Saw will lnot start----needs gas intake adjustment
Turn both jet screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that will allow the engine to start and run. Let the engine warm up, then pull the throttle full on--turn H screw CW until the engine speeds up somewhat. Proper adjustment is when the engine is 4-stroking unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 14, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carburator settings
If you have played with them the only way is to get it going pretty well is" ....
find the idle screw - usually larger - and turn in 1/2 a turn - hopefully that will keep it running - then find the 'slow' running screw turn it in until it stops then turn out 1 and 1/2 turns. Leave the fast one alone.
Get it started then adjust idle screw so its faaster if need be.,, now slowly turn the 'slow' screw in then out say 1/2 turn and listen for it either speeding up or slowing down leave it at the point where it sounds ok and try giveing a few 1/2 speed rev ups. If it goes back and idles as before - leave it.
The fast screw... (first make sure your exhaust outlet is totally unblocked - the slightest restriction here will cause it to never run right at high speed). Start it up and then try full throttle - same thing as before try adjust the fast screw first in a little then out until it runs well at what seems the faster speed it can - then check that it accelerates well from idle to full speed. If not adjust it a little more until it does.
Once it will idle ok and return to idle and also run full speed, then you can back off the idle screw until it will idle without the chain racing arond the bar.
Bear in mind th chain wil be racing around while you adjust it so keep fingers kids and idiots well away..because you are adjusting it with that chain moving..
Nov 07, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
16'" Wildthing wont Idle after turning the "t" throtle screw
screw it in and then back it out until it idles, may have to keep it running by giving gas and lettting off of gas until you find the correct idle speed
Jul 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
4 y/o oulan chain saw hard to start and quit running, no spark.
May 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Runs to fast
You need to adjust the idle and high speed screw settings on the saw. Consult your user manual for tuning the engine.
Feb 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
892 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
