Question about Lexmark Office Equipment & Supplies
Hi I have a lexmark x1180 and have just installed new cartridges however when printing text it is printing two of the same very close together (so it looks like double vision) also when trying to print the test page it is printing an black and white.
  • 109 Answers
It sounds like your cartridges should be alligned. In your Lexmark 1180 Program Group (Start->All Programs->Lexmark 1180) there should be a Lexmark Solution Center or Lexmark Productivity Studio.
If Lexmark Solution Center - go to the maintenance tab and run the alignment process.
If Lexmark Productivity Studio - click on Printer Maintenance and then select Align
Steve
Posted on Sep 11, 2008
Error message print cartridge missing
Does this happen with every cartridge you install ?
I've seen this problem before with several brands of printers, it's usually a sensor issue connected to a fairly flimsy 'ribbon' wire. Either the wire (ribbon) has come loose or the sensor has failed. Hopefully this isn't your issue as the cost of repair is usually more than the cost of a new printer.
Jun 28, 2012 | Lexmark 17 & 27 Ink Cartridges X1150 X1180...
Replaced Black Cartridge...will not function
hi hello i tell you try replace that cartridge of yours. if your still use it, not working.. that cartridge is damage..
Jun 16, 2009 | Lexmark X1150 All-In-One InkJet Printer
Lexmark x1180 printer
Hi Malam454,
Thanks for the posting in FIXYA.
Is it attached to your HP Laptop in Network through LAN Cable?
Does any flag shown in the Device Manager list?
Try this -->
Go to Start -->Printers and Faxes..
Now, right click on your Lexmark printer icon and select "Properties"..
Click on the "Port" tab along the top..
What port does it say you are using??
Try after unplug and replug the cables.
Regards
ELLIN
Sep 14, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1180
don't have disk to install lexmark x1150
Jul 31, 2008 | Lexmark P915 InkJet Photo Printer
Lexmark x3550
Changing print cartridges Changing print cartridges Removing a used print cartridge
  1. Make sure the printer is on.
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier lever to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. Installing print cartridges
  1. If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
    cartridge_tape_remove_one_2.jpg Warning: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
  2. Press down on the cartridge carrier levers to raise the cartridge carrier lids.
  3. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier.
  4. Close the lids.
  5. Close the scanner unit, making sure to keep your hands out from underneath the scanner unit.
    scanner_unit_close_2.jpg The control panel display will prompt you to load paper and press button_select_0.jpg to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job.
Jul 22, 2008 | Lexmark X3550 All-In-One Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Installation
Sure you can install without a disc but you need to download the setup from Lexmark.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X1180
Click on the operating system that you have and then download.
Mar 19, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180 blank ink not coming through
You can refill cartridges only a certain number of times.
Check the copper contacts and see if they look like new. any amount of wear and they wont work anymore. That being said, All printer manufacturers say to buy new and not refill.Maybe that is a moneymaker for them, however, I have never had good luck with refilled cartridges.
Oct 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
