Question about PC Chips (M791G) Motherboard
Usb slot of ecs m791g
The usb slots at the back are all not working
    Sergeant:
  • 300 Answers
Did you enable the USB ports in the BIOS , and make sure they have an IRQ assigned ?
Also lets recall that USB 2.0 is enabled by installing service pack 2
I'm certan that will solve your issue.
shalom
Posted on Sep 11, 2008
What memory and processor use Q35T-GB
Socket Type: LGA775
Supported Memory: DDR
Onboard Video: yes
Onboard Audio: yes
Graphics Expansion Slot: PCI-E x16
PCI Slots: 2 PCI, 1 PCI-E x1
USB Ports: 6
VGA Ports: 1
This should be the homepage:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2654
Good luck
Mar 16, 2013 | ECS Q35T-GB Elitegroup Type Motherboard...
My ecs G31T-M motherboard goes on but not my display what can the problem be.
If you have a built in video card, I suggest you clean the connection of your memory card, you can use a pencil eraser to clean the contacts and with a soft brush clean the inside of the slots, insert back the cards and power on your machine. If did not help, try to insert a video card in the slot and power the machine on, if it works your problem is solved. If none helped I suggest you buy a new board.
Sep 03, 2011 | EliteGroup ECS G31T-M Motherboard - Quad...
Usb plug ins do not work on motherboard, is it better to just replace the motherboard and start over
Unfortunately it's not unusual to get a laptop or mb that has some USB slots that don't work. I'm assuming you've checked to make sure all the power wires are connected? If it's all connected and not working I would exhange the board rather than trying to fix it.
Mar 23, 2011 | ECS C51GM-M Motherboard
I have put a "GB DDR2 -800 in each memory slot in
because there is a defect with the dimm slot 2 on these mobos.I have the same problem.contact ecs therell give you a bios update but it wont work
Nov 09, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
How to install memory on ecs G550 laptop can only see one slot with 512 MB ddr sodmmm where is the other slots to upgrade to 1GB ram
There are two memory slots which support PC2700/333 Mhz memory, maximum 1024 per slot.
ECS suggests using identical/matched pairs of chips from the same manufacturer for their units.
In most laptops there is an access panel which when removed gives you direct access to the memory chips for replacement. I couldn't find a mainboard diagram for this unit so I am unable to see if the memory slots are adjacent on the board but there is little reason they shouldn't be. You should be able to access both slots once the proper access panel is opened.
This is the website page for direct contact with ECS tech support if you have any further questions: http://www.ecsusa.com/ECSWebSite/Support/TSSRequest.aspx?CategoryID=3&MenuID=19&LanID=0
Feb 05, 2010 | Generic Memory Computers & Internet
Vga driver for ecs M791G
KENAPA PCI-E VGA SAYA ECS KN1 SLI LITE / C51G-N754 TIDAK MAU DISPLAY, SEDANGKAN WAKTU SAYA BERI VGA DISLOT PCI MAU DISPLAY?
Oct 13, 2008 | ECS KN1 SLI Lite (V1.0A) Motherboard
Beeping M791G PCChip MotherBoard
Check the RAM slot of your motherboard that if its properly installed or not. or else remove the RAM and clean the slot and insert it properly. Hopefully it should work. Thank you
Sep 09, 2008 | Intel Motherboard
Ecs mb model p4vmm2
in as much as there is a ddr slot, it could be used, no need to adjust any switch.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Oct 20, 2007 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
PC Chips (M791G) Motherboard Logo
148 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
