Question about Acer Computers & Internet
I want to change the SATA MODE to IDE I don't know how I was told I can do this in BIOS mode. ACER TRAVELMATE 290E
    Master:
    Sergeant:
  • 388 Answers
Do u have any SATA devives inside of your computer because i have built a lot of systems and as far as i can tell there is no mode that makes SATA or IDE work, the computer scans to see if there is any devices of the type and acts accordantly so maybe some more info on what you are try to do may help me help you more.
Posted on Sep 11, 2008
When I turn on my computer the screen says " A disk read error occured" "Press Ctrl+Alt+Del to restart. I press that and then this screen comes up... Me having the happy fingers I changed...
Hi sharetta lan...
To change the ide mode back to sata mode you will have to enter the bios.
To enter the bios you will start the computer and as it is starting tapping the delete key,F2 or F10 key depending on your computer.
Once you are in the bios you can change the ide mode back to sata mode.
Please take time to rate me
Sep 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Every time i try to install windows xp on this laptop i just keep getting an error message. i was told i need to disable the AHCI, how do i go about doing this?
Installing XP on a SATA drive requires an additional step:
http://xphelpandsupport.mvps.org/how...ws_xp_on_a.htm
However, Most newer BIOS allow an Alternate method for SATA . . Go into the bios and check the "Sata Operation" setting,
change it to "Raid Autodetect/ATA if it is not already. Now try to install XP ( could be IDE Mode, Compatibility Mode or Legacy Mode - different BIOS use different terms )
some will say IDE instead of ATA)
If there are no such settings you'll need to slipstream the sata drivers on the XP CD, follow the instructions in this guide :
http://www.digitgeek.com/how-to-slip...rs-into-xp-cd/
or
http://www.howtogeek.com/howto/windo...-installation/
Or, you might consider installing Windows 7 . .
Jan 24, 2011 | HP Compaq Presario CQ61420us Notebook
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
No bootable device for acer aspire 4730zg
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----RESTART YOUR SYSTEM AND THEN CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Acer Aspire 4730-4947 Notebook
Make sure your scsi disk is turned on refer to manualwhen installing windows xp pro, acer travel mate 290. then states use another partition but comes with the same message one of your disk is damaged...
yes indeed nowadays laptops are designed for windows vista and better versions as these are equipped with SATA harddisks. to install windows xp in these systems u need to change SATA settings in bios which can be done by 1->pressing F2/DEL key during the starting acer empower people screen which v get once v switch on the laptop 2->in the BIOS screen go to MAIN tab by pressing right arrow 3->scroll down till u get SATA mode->press enter .two options ll be available 1.AHCI 2.IDE 4->select IDE and press enter. 5-> go to exit tab and select save and exit 6-> now try installing xp pro!!
Jan 11, 2010 | Acer TravelMate 290 Notebook
Extensa 5630/5330z/5630z/5230 series model no ms2231
Ok, if it is as what i think, the solution is very simple, just inter the SETUP (F2) and change the SATA mode to (IDE), the default is ACHI if i'm correct, i dont have time to enter the BIOS to get the right name, just do it..
enter the bios and change the SATA mode to IDE, then save and exit. now you can install XP..
have FUN
Apr 24, 2009 | Acer Extensa 5620-6119 Notebook
RHEL %
change HDD mode in bios setup and try.
it seems that RHEL is not supporting your SATA hardisk.
Aug 01, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
