Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Deep Sleep My TV keeps going into deep sleep within seconds of being turned on. It started when I tried to watch a video on my DVD last night. As i was going through the inputs trying to get to the right one it went into deep sleep and shut off. Now when I turn it back on and try to go through the Inputs to get back to TV it shuts off. When I am on TV it doesn't see the signal either. My cable box etc is all turned on correctly
  • 3 more comments
  • Anonymous Dec 27, 2008
    sometimes my vizio goes into deep sleep when I turn it on
    sleep
  • TeenaCardoni Jan 22, 2009
    I HAVE THE SAME PROBLEM...I CAN'T FIND THE SOLUTION. PLZ ASSIST
  • nzi1234 May 20, 2009
    My vizio Plasma keeps going into deep sleep, any help?
  • Anonymous May 23, 2009
    My Vizio has the same issue, and my does it at random. Please HELP !!!
Use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Posted on Jun 19, 2009
Posted on Sep 29, 2008
I used the actual TV input button instead of the remote and for some reason that worked. Thank you!
Posted on Sep 12, 2008
Going in a deep sleep
Posted on Oct 20, 2008
SOURCE:
Why wont my L9 to into sleep mode
Hi Orlando,
I have this site for you where you can download a software where you can set up deep sleep battery saver for your phone. Hope it helps.
Deep Sleep Battery Saver Pro
Apr 28, 2014 | LG Optimus L9
Tip
How Can a Sleep Mask Help Me?
Sleep isn't something that we can do without. Not everyone seems to need the same amout of hours sleep but a block of sleep is necessary every night in order to function well during the day.
Insomnia is a problem on some level for millions of people world wide and people use all sorts of solutions; from drugs to herbal remedies, meditation to sleep masks.
In order to feel rested, we need to have Deep Sleep. Sleep occurs in cycles. Deep sleep or REM is the fifth of the sleep cycles and is the most important one.
Deep sleep allows our minds to really sift through memories, stress and feelings. The body at this time might appear very active as extremitites can be twitchy and blood pressure and heart rate can increase but actually the body is going through a period of great rest.
So if deep sleep is so good for us - how do we get more of it?
Both quantity and quality matter when it comes to sleep. You need to sleep enough hours so that you have time for deep sleep cycles.
But when it comes to quality of sleep, there are things you can do to help yourself.
- Make sure you dont' have any lights left on. Even small computer lights can disturb sleep.
- Have a regular bedtime routine that you try and follow every day so that your body knows the signals.
- Use sleep masks to aid a deeper sleep. They will block out any tiny light and allow you to really fall into a deep sleep.
- Sleep masks are also really helpful for people who need to sleep with some light on.
Getting a good nights' sleep can help with mood, weight, memory and even our immunity to getting sick.
It's such a simple need and yet so many people don't listen to their bodies.
So I suggest that you invest in a sleep mask, follow the steps above and see if it helps you to feel better.
on Jan 06, 2014 | Health & Beauty
Going into deep sleep
Do you want to prevent your laptop from getting into deep sleep or are you having problem getting into deep sleep?
Sep 17, 2013 | Microsoft Computers & Internet
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Ipod in sleep mode
How to Enable Sleep Mode :
1. Access the main menu on your iPod
2. Go to the extras menu > clock
3. Select your current time ensuring that your timezone settings are correct
4. Select the Sleep Timer options
5. Select the time that you want your iPod to shut down
And if your iPod goes into Deep Sleep Mode then here is the answer to that :
Right "Deep Sleep" is a battery saving mode if the iPod is not touched in say a 18-24 hour period I think. It reboots (resets) coming out of this mode.
1) There are people reporting that they must always reset their iPod to turn it back on after shutting it off, they don't really mention deep sleep at all, search for "must always reset" or something along those lines
2) I'm not sure if this is documented anywhere specifically. It is a normal function of the iPod that we discovered somewhere along the line. Not sure where the first talk about it came from, you may find information on this searching "deep sleep" there was a hack to force the iPod immediately into deep sleep once upon a time.
3) Not exactly. If an iPod has gone into deep sleep, plugging it into the power will automatically start the reboot. In the case of buttons you should be able to touch a button and it will start to reboot, I have found with my 3G iPod it takes a very deliberate touch or two or three touches to the touch sensitive buttons to get it to wake up, but you shouldn't HAVE to do the reset command (i.e. menu/select button held down), if you do you may be looking at more of the original problemin #1
Sep 19, 2009 | Apple iPod touch
Plasma vizio 50 inch goes into deep sleep mode
when turned on tv no signal comes on a few minutes later deep sleep mode and tv turns on
Sep 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
No signal...deep sleep
Go to main menu, turn off sleep mode, then find the "autoprogram" feature and select it.
THis will program all available channels, just make sure you tv is set to AIR for regular tv and CATV if you have cable.
The thunderstorm may have reset the television. Hopefully there is no damage done to the tuner
Jul 29, 2009 | Vizio VX37L Television
My sims ds lite
IT GOES 2 BED AT 9:00 I THINK
Jul 23, 2008 | Nintendo DS Lite Console
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
5,474 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
