Question about Carrier Heating & Cooling
Carrier Phoenix Ultra XL Reefer Water Pump part number V2203 engine
2 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: i have a carrier reefer
Check for dirty evaporator coil, restricted liquid line filter, or defective expansion valve.
Posted on Aug 04, 2008
Where is the drain plug for the block drain on a Kubota engine V1902-B?
[PDF]KUBOTA DIESEL ENGINE - Waterax
waterax.com/app/uploads/2015/09/ENGINE-MANUAL-D902.pdf
engine maintenance. it is KUBOTA's policy to utilize as quickly as possible .... Be sure to close the coolant drain valve, secure the pressure cap. and fasten the .... Oil drain plug. (18) Oil ... around the machine. it may catch on moving (B) "OFF".
Kubota V2203 Block Water Drain? - Diesel Bombers
www.dieselbombers.com > ... > Diesel Engine Conversions
Nov 21, 2013 - On my Kubota V2203 DI above the Oil filter is a long bolt of which the only thing ... I did not even know that Block Water Drain was there till last night I ...Also, the pipe plugs in the engine are a Japanese style, but we've ... Kubota v2203 vsv1902, ziegler, Diesel Engine Conversions, 4, 01-10-2015 06:27 PM.
Kubota Engine Service Tips
johnsoncitykubota.com/Kubota%20Engine%20Service%20Tips.htm
If the reading is 11 volts or more while you are trying to crank the engine see the ...Other causes include defective glow plugs or low cranking speeds from a weak battery.... We have not seen it "ruin" anyone's tractor yet, so drain the tank, refill with ....passages between the cylinder head and the block became 90% blocked.
Kubota L2550 needs block heater! - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tractors
Jan 25, 2011 - 25 posts - ‎14 authors
Oldmax, I could swear I was looking at a closeup of my engine, except for the colour.... V1702, V1703, V1902, V1903, V2003, V2003T, V2203 (4 cylinder) Part No. ... BSeries (Except 2 cylinder) Part No. Watt Volt Diameter Type .... Paul, does the tractor have a block drain plug, and a thermostat bypass ...
Jan 06, 2016 | Cars & Trucks
ALARM AL-15 ON CARRIER REEFER
hola qtal como estas, tengo un problema con un reffer de carrier modelo thinline con motor resiprocante que me da alarma al 15 y para el equipo no baja ninguna llave solo protege
Jan 08, 2012 | Carrier Refrigerators
Need to know what the specs are for v2203-e head bolts torque
Do you mean a Kobuta v2203 e diesel engine? This looks to be in the Air Compressor section?
Anyhow, the specs for that are here: http://www.frontierpower.com/kubota/oldkubota.htm#Super3
Jan 12, 2011 | Air Tools & Compressors
I have a carrier reefer displaying a alarm code 15, not in the manual can someone tell me what it means and what to look for?
ti'm a reefer engineer in iran you have 3 answer:1-the refrigerant in system is low or 2:the control board is failed or 3:the suction line has frost and you must to doing manual defrost in your system,,good luck <sina>
Nov 10, 2010 | Carrier Heating & Cooling
I just got a G E refrigerator from home depot model # gbscohcxarww. And the freeZer on the bottom works but the ref rig on top doesn't get cold
set dials to middle setting, max cold makes cold freezer, not reefer box!! if freezer makes ice its ok just set to cold which starves reefer box of air. add 2-3 gallons of water to the freezer and or reefer box, if empty it wont cool much.
Nov 01, 2010 | GE Refrigerators
How do i replace a water pump on a 1997 vw passat
Water Pump REMOVAL & INSTALLATION 1.8L Engine NOTE: The coolant pump is bolted to the brackets for the generator, power steering pump, and cooling fan.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Position the lock carrier into the service position as follows:
    1. Remove or disconnect:
      • Front bumper.
      • Any wiring or connector that would inhibit locking the carrier.
      • 3 quick-release screws on the front noise insulation panel.
      • Air guide between the lock carrier and the air filter.
      • Retaining clamps for the wiring harness at the left side of the radiator frame.
      • No. 2 bolts and install Support tool 3369 or equivalent.
      • Remaining bolts and pull the lock carrier out to the stop.
    2. To secure the lock carrier, install the appropriate M6 bolts into the rear of the lock carrier and fender.
  3. Remove or disconnect
    • Negative battery cable.
    • Accessory drive belt, then the engine driven cooling fan.
    • Coolant.
    • Clamps for the coolant hoses at the water pump.
    • Intake air duct between the intake manifold and the charge air cooler.
    • Generator mounting bolts and slide it forward.
    • Wiring from the generator once it is removed.
  4. Unbolt the following supports and brackets for the generator, power steering pump, and engine cooling fan:
    1. Intake manifold support
    2. Support for the engine torque bracket
    3. Brace to the cylinder block (remove completely)
  5. Remove or disconnect:
    • Brackets for the generator, power steering pump, and engine cooling fan, positioning the brackets to the left side using a piece of wire
    • Coolant hoses from the pump and thermostat housing
    • Coolant pump housing from the timing belt cover
    • Coolant pump mounting bolts, then the pump
    • Impeller housing from the pump housing
    To install: Fig. 1: Exploded view of the water pump, housing and related components — 1.8L engine 9301wg04.gif
    Fig. 2: Assembly bracket with water pump mounting bolt tightening sequence — 1.8L engine 9301wg05.gif
  6. Using a new gasket, mount the new coolant pump to the pump housing. Mounting bolts: 84 inch lbs. (10 Nm).
  7. Using a new gasket and O-ring, install the coolant pump. Mounting bolts in alphabetical sequence: 18 ft. lbs. (25 Nm).
  8. Tighten the coolant pump housing to the timing belt cover to 84 inch lbs. (10 Nm).
  9. Install or connect:
    • Coolant hoses to the pump and thermostat housing.
    • Brackets that were removed. Mounting bolts: 18 ft. lbs. (25 Nm).
    • Wires to the generator, then install the generator.
    • Air intake duct between the intake manifold and the charge air cooler.
  10. The remaining steps are the reverse of the removal.
  11. Fill the engine with coolant
  12. Fully close all power windows to stop, operate all window switches for at least 1 second in the close direction to activate the one-touch opening/closing function
  13. After installing the lock carrier, check the wiring for proper routing near the cooling fan
Aug 11, 2010 | 1997 Volkswagen Passat
TRUCK REEFER UNIT ERROR CODE A20
Please use the "continue with this expert" option and explain with greater detail your problem.
Please include Make & Model number of your refrigerator you are getting the a20 error from... and what symptoms you are experiencing for a more comprehensive answer.
Thanks!!
Jun 12, 2009 | Carrier Refrigerators
I have a carrier reefer trailer phonix ultra xl that at 25 degrees the low side drop in to a vacuum
Aug 03, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
1,450 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
