Question about Nortel MER-9417CW Telephon Corded /2 Line Speakerphones with Caller ID and Call Waiting, Almond (MER... (A0674968)
Phone Hums Phone humes when I plug it in. The new adapter gets hot. Eventually the display will go out. I have a dial tone but there's lots of noise on the line.
    President:
  • 3,130 Answers
Theres a short inside the phone. The best way to troubleshoot this is to take apart and try to feel if an IC or part is getting hot or use a metter to check.
Posted on Apr 20, 2006
I have a line phone. I cleaned the top of it and must have touched something because I now have no dial tone. I recently purchased 2 Uniden no line phones no dial tone on them either. The model # is 1818...
Try reset the phone in question, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Jun 16, 2011 | Uniden Cordless Phone
Own a GE 29870GE1 telephone with digital answering machine. The digital part works but can't get a dial tone.
Try unplugging the phone from the wall power outlet plug it back after like 3 minutes. Power on and see if you get a dial tone, if not, try reset the unit, once the unit is reset, the problem should be fix. Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Take care.
Sep 23, 2010 | GE 29897GE1 Corded Phone
We had a thunderstorm and a transformer was struck by lightening. I have no dial tone. Do I need another AC Adaptor. The display screen is blank. My other telephone worked ok when I plugged it up....
What all you need can be decided upon after eliminating the faulty items one by one. First the AC adapter. Check with another device if the adapter is functional. Or if you have a multimeter. Next the phone, try another adapter. Where from? Read the specs printed on the adapter. It will tell you the Input and output voltages. Then it also tells you about the frequency. Then the wattage. If all of them match or come close you can use it. Trip to the store is warranted. Thunderstorms and lightenings generally do not leave anything intact. So, I hope your phone is intact. Adapter can be replaced easily.
Aug 05, 2009 | Meridian 9516 Corded phone
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
May 28, 2009 | Uniden Cordless Phone
My phone has no dial tone.
Check if the cordless works on a normal telephone line,Plug in another instrument to see if you get dial tone,light.
That's it you should know what is causing the problem.
Samir
Dec 27, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
We have recently purchased a brother mfc-240c, and as far as i no i have installed it correectly yet when trying to use the fax it dails a dead tone and continues to redail but doesnt send, and we...
make sure you have a dial tone by plugging a different phone into the jack. then make sure you have it plugged into the jack on the fax that says line.
Mar 08, 2008 | Uniden Cordless Phone
Display blank, no keypad tones, Emerson EMG900 phone
you must use a ac adapter which the phone doesnt come with or 3 double A batteries
Dec 16, 2007 | Emerson EMSEM2646WH Phone
Sakar Telephone Problem
This Telephone doesnt have a capability to work with shared connections where u use more than one phone in one connection.......... And this phone cannot be charged it works in either battery or Adapter...... Good Luck......
Dec 10, 2007 | Sakar Talking Caller-ID Speaker Phone
Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
Polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
Lands Phones Logo
141 people viewed this question
Top Nortel Lands Phones Experts
vince
Marvin
Marvin
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
