Question about BenQ FP731 17" LCD Monitor
Power light on but no viuals
When switching the monitor on the screen does show its on and the power light is also on but there are no visuals. I see a couple of people on the net with the same problem and I don't think the suggested solutions are helpful. Does it mean the Monitor has a 3 year long life only.
    Champion:
  • 293 Answers
Hi..there,
It's seems your backlight inverter are burnt out... Need to replaced a new one or repaired it.
Posted on Oct 17, 2008
Monitor is blank and the power light keeps flashing green.
When you switch on both Poota and Monitor, is there visual startup flashes or startup information showing on screen.
Make sure the monitor connect to rear of poota is located and firmly in place and properly screwed in?
Nov 12, 2009 | Dell E196FP 19" LCD Monitor
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
AOC lm720 no screen plus blinking green light
Sorry to say, but it sounds like you power board is due for an overhaul.
It should be fixable since it does show signs of a little life left in it.
It would have to be taken apart. A visual may tell for sure.
Look for bulging capacitors (canister looking things) This a sign of a typical failure.
Of course, not all capacitors bulge when they go bad. That would make things too simple !!
ebaysbammbammfran
Oct 12, 2008 | AOC LM 720 17" Flat Panel LCD Monitor
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
Display problems please help
This seems to be a problem of the Invertor or powersupply board.If you are technically able check the boards visually,look for bulging discoloured capacitors. Try replacing these components it may solve your problem.
Please provide feedback and rate the solution.
Samir
Jul 25, 2008 | Samsung SyncMaster 731B 17" LCD Monitor
Screen doesn't work properly. Can just see windows loading if hold screen to light. Computer Compaq Presario V2157Ap or V2000 both nos on back of comp
1st test,- connect an outside [test] monitor to the back .There is a VGA plug somewhere back there. If the screen come in good, the problem could be your Laptop monitor screen.
If the connected test monitor acts the same, visually, the problem is in your Laptop.
2nd.test- goto BIOS setup and press F=function that set your laptop to DEFAULT, reboot and see.....
3RD. test- [POWER OFF!!] switch ram chips around from one socket to the other ,, reboot or power on
4th:replace memory chips with KNOWN good ones
If u still have problems, goto technician for help
May 06, 2008 | Computers & Internet
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
BenQ FP731 17" LCD Monitor Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
