Question about Brother IntelliFAX 4100 Laser Fax
Error 77 is apprearing
First error 76 appeared on screen. I unplugged machine. Plugged everything in again and error 77 came up.
Unplugging does not correct situation
What next?
I need the fax machine STAT!
  • Anonymous Nov 04, 2008
    I have Brother 5750e Fax have error code 77, can sum 1 help
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Posted on Sep 08, 2009
    Genius:
  • 2,120 Answers
Probably a bad fuser.
Error codes shown in the "MACHINE ERROR X X " message
Error Code
X X
(Hex.)
Error factor
( 71 Polygon motor does not synchronize with the reference clock. )
( 72 Cannot detect Beam Detect signal. )
( 73 No toner cartridge loaded. )
( 74 Toner empty. )
( 75 In-casing temperature error. )
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
( 79 In-casing temperature sensor harness disconnected or broken. )
( 7A Main motor does not synchronize with the reference clock. )
( 7B ASIC error on the main PCB. )
( 7C Engine PCB error. )
( 7D Abnormal discharge of the corona wire detected by the toner sensor. )
( 80 Paper size setting error. )
( 82 Paper feeding error. )
( 83 Paper jam. The registration sensor, 2nd registration sensor, and/or manual
insertion sensor remains ON.)
( 84 Paper jam. The paper ejection sensor remains ON. )
( 85 No paper cassette loaded. )
( 86 No 2nd paper cassette loaded. )
( 88 Paper jam. Even after the registration sensor has gone OFF, the paper
ejection sensor still stays OFF.)
( A1 Front cover opened. )
( A2 Document too long to scan. )
( A3 Document not detected by the document rear sensor. )
( A4 50% or more faulty of white level data. )
Error codes in parentheses do not appear in the "MACHINE ERROR X X", since those errors are
displayed as messages described in "[ 1 ] Error messages on the LCD." In the maintenance mode
(Function code 82), those error codes may be displayed.
VI - 6
Error Code
X X
(Hex.)
Error factor
( A7
Posted on Oct 06, 2008
I have a samsung washing machine, a error message came up on the screen. 3e. we were advised to contact our after sales. we did, we were told by a service eng; the mother board was dud can you please...
Switch off the power/reconnect and try again, try unplugging power cord for two minutes, if problem persist follow instructions at the end of user manual to call service
Jul 24, 2008 | Samsung Washing Machines
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
Error Code 77 on brother 4100 fax intelifox business class
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
Machine error 77
Hello there, in a situation like this the best thing for you to do is to call Brother customer service at 800-284-4329 and explain the problem.
Thank you
Jul 16, 2010 | Brother IntelliFAX 2800 Laser Fax
Machine error 77
Have you tried unplugging the machine, holding down the Menu/Set button while plugging back in. Release Menu button. Enter 91. Enter 99. Machine should say please wait while warming up. Let me know.
Dec 09, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother MFC 9030
Open the printer and check to see it your fuser is worm up. Do not touch the fuser. If it is cold. you have a problem.
You fuser may be at end of life. Need to be replaced.
cost price of fuser and labor will come close or above cost price of machine. your choice.
Good luck
Jul 24, 2008 | Brother International Plain Paper Fax
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
1,139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
