Question about NEC VT460 Multimedia Projector
Whatever button i press the status light flashes and nothing happens?
Even when the projector is switched off i can't use the buttons to switch it on. Every button makes the status (yellow) light switch on. Any ideas will be very appreciated.
  • Richard Horn Apr 24, 2006
    I phoned NEC and found the solution. The keylock was on. If you hold the cancel button for 20 seconds the keys can be used again. thanks for your help
    Champion:
  • 277 Answers
Hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Posted on Apr 23, 2006
SOURCE:
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
NEC VT 660 Status light on
ok try this take the batterys out of the remote for a few minitues and turn the projector off at the wall so it looses the memory and the remote should to
Sep 07, 2008 | NEC VT47 Multimedia Projector
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
Keeps switching inputs
WD82837: Mitsubishi 82" Rear Projection
Problem: The "status" light flashes yellow while no picture display. Nothing happens when pressing the power button. The light keeps flashing if plugged in. I cannot test for codes by holding for 5 seconds as there is no place to check the code problem due to no display. HELP!
Feb 07, 2014 | Mitsubishi WD-82837 82 in. HDTV DLP TV
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
How to reset lamp after replacing the lamp on epson emp x5
1. Make sure, your projector is on standby.
2. While holding down the projector's Comp Sync + and Comp Tracking + buttons, press and hold down the power button.
3. After status light 1, 2, and 3 flash ON and OFF at least three times, release the Comp Sync + and the power button. The flashing lamps status indicate that the lamptimer is reset.
Aug 02, 2011 | Epson EMP-X5 LCD Projector
My NEC MT1060R will not turn on and the status indicator is flashing red four times, before and after I changed out the lamp.
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual. (It could have been the on button, can't remember now)
Good luck
Nov 30, 2010 | NEC MT860, MT1060, 1060R and 1065...
Reply to your question
One more question... when you plugged the projector in ac outlet, did it give smoke, smell or something?
Jul 24, 2008 | NEC VT460 Multimedia Projector
Flashing red status light on NEC VT45 projector
make sure the doors are shut all the way! there is a little button there.
Feb 13, 2007 | NEC MultiSync VT45 Multimedia Projector
NEC VT460 Multimedia Projector Logo
687 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Adorjani Laszlo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
