Question about Acer Aspire 1690 Notebook
Quick memory compatibility question (Picture)
Hi, i have the aspire 1690 and it has the following RAM already...
Im sure my laptop is DDR memory but is this 3200 or 333mhz
basicially is this the right type or this
Thanks
Michael.
    President:
  • 2,961 Answers
The easiest thing to do is run this programme from Crucial, it tells you the type of memory fittted and the max you can fit exactly.
Posted on Sep 11, 2008
Information about how to expand RAM in Acer Aspire 1403LC
Most RAM will work with each other, but the safest way to be sure is by checking the speed. On the stick that is in there now you should see a label that says something like PC2100 DDR. I looked up the specs of your computer and this RAM should work for it.
512MB DMS Certified Memory 200 Pin DDR PC2100 266MHz 64x64 CL 2 5...
Jan 23, 2014 | Acer Aspire 1403LC Notebook
Can i use DDR2 SODIMM 800MHz PC6400 in my laptop even though the one in it now is a DDR SODIMM PC3200 CL3?
pc3200 is original ddr- ram but pc6400 specifies to ddr2. The ram is not compatible. And the key slots on your mainboard will prevent installation.
Aug 20, 2011 | Compaq Computers & Internet
Can I upgrade the ram on the acer aspire 5630 notebook?
Yes, you can.
You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Nov 25, 2010 | Acer Aspire 5630 Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
Want to install 4Gb
memory is a tricky thing you have to make sure that the meory is compatable with your mobo(for instance) my laptop is a acer aspire 3000 it takes pc2700 ddr memory that runs at 333 mhrtz i just upgraded from a 128 and 512 set to 2 gig im running xp home,also xp will only recognizes 2 gig max unless it the 64 bit ver which then will go up to 4 gig and up also vista as well will run up to 4 gig and up usually 64bit ver will recognize 4 or more gig however if you need soem more help id need make model of laptop your running as swell as which ver of windows.happy hunting-z
Jan 30, 2009 | Acer Extensa 4620 Notebook
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
I want to upgrade memory of my laptop acer aspire 1691 from 512 to 2gb. Can you tell me which one to buy and how to install them. have you got any manual for acer aspire so that I know where to open and...
it's easy to add memory.
Just open the door on the back of your laptop.
You can see 2 slots of memory.
Make sure that you know the type of your memory for your laptop. I believe is DDR (not DDR2).
May 07, 2008 | Acer Aspire 1690 Notebook
Memory
The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
This information can be found on Acer website.
If this solves your problem, please mark this as Solved.
Thank you
Oct 12, 2007 | Computers & Internet
Acer Aspire 1690 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
