Question about Bugaboo Cameleon Jogger
Wheel make terrible noise - Bugaboo Cameleon Jogger
  • 20 Answers
This could be cause by a few different things:
The brake on the Cameleon is similar to a bikes. If the brake is too tight, it may cause the rivited braking system to come into contact with the wheel's rivets. You can loosen the braking system so that it will not make such noises. If you follow the braking cord down to the wheel, you will see a small nut that is controlling how much slack the brake has. Loosen this, and it will cause the brake to be further away from the wheel's braking rivets.
If this does not work, contact us and we will try and develop a video to help in your problem.
strollerinfo@gmail.com
StrollerInfo
www.strollerinfo.com
Posted on Oct 02, 2008
Why does my machine make a terrible screaming noise
try oiling parts
remove any thread around the bobbin carrier shaft
take it in for a service
Jun 16, 2016 | Sewing Machines
What's causing my 2001 hyundai accent to be noisy when moving on the driver side front wheel?
It could be the disc brake pads telling you they need to be replaced.
Jan 19, 2016 | 2001 Hyundai Accent
Rincon. Why is there grinding noise in rear end and rear wheels will not drive?
Could be bad u-joints, wheel bearings. Raise rear of vehicle and rotate wheel by hand, if noisy remove and replace. Hope that helps.
Dec 18, 2015 | Honda Cars & Trucks
Grinding noise around front wheel hub on Chevy cavalier
I would guess it is your wheel hub, but if it occurs while the car is on and not moving, it might be your a/c compressor. When they go out they make a terrible grinding noise.
Jun 05, 2014 | 1999 Chevrolet Cavalier
I need a fly wheel. How much should that along
the flywheel will only make noise when its starting. it sounds like you have a tensioner going out.
May 17, 2010 | 1995 Chevrolet Lumina
Dryer is making a terrible racket, but drys perfectly.
It depends on the noise. It could be a drum roller going bad, the idler pulley, or even something caught in the blower wheel. Can you describe the noise?
Jan 01, 2010 | Dryers
Noise in rear wheel
EITHER MOISTURE OR BRAKE DUST.
Dec 30, 2008 | 1993 Lexus Ls 400
Terrible noice when I turn the steering wheel on my 2001 BMW 325i
Make sure you check your power steering fluid... if it's even low, it will make a terrible noise...run it on empty too long and your can ruin your power steering pump.
Dec 27, 2008 | 2001 BMW 325
Terrible noises
This would sound like possible differential noises, possibly a spider gear has a broken tooth or other defect. You could raise the backend off the ground (both wheels or one wheel at a time); place shifter in neutral, then have a friend turn one wheel, while the other is held in place (or left in contact with ground). If you get similiar (but probably less terrible), then remove the diff. cover (pan for oil needed), and look for any visible defects. Services of a mechanic might be needed.
Jun 03, 2008 | 2001 Dodge Dakota
Bugaboo Cameleon Jogger Logo
584 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
