Question about Raymarine RL70CRC GPS Receiver
Keeping course
Hi my autohelm will not keep a course when entered and set.
I.E. I ask it to steer a course say 150 and set it. it will go off and stter the boat in circles but not that course. The unit has been reset to default and the flux gate was replaced.After flux gate was replace it worked for a while then started loosing course again
  • 38 Answers
Please check if the pilot is acting the right direction ,press +10 key and check if boat teers STB,
press -10 and check if boat turns PORT ,if it acts reverse, see handbook to reverse action.
Verify if compass course in standby is indicating correct course .
Do the calibration procedure as stated in in the handbook (360 degree turn)
If it still not indicate the correct course ,or is frozen, compass or printed circuit is faulty.
Check the resistance between the wires of the compass unit .(see google internet)
Good luck
Jean
Posted on Apr 30, 2009
How to remove steering column cover
hi most mercs of this age are mostley the same where the steering wheel is look underneath that where your peddles are that is a large panel with around 7 to 8 screws keeping it in place remove this pannel when this is removed you should be able to see more screws keeping the steering colum plastic in place you may also need t remove the steering wheel first disconect battery as the srs light will come on and will need reseting if not behind the wheel there are 2 screw holes which are small star keys this removes the air bag once air bag is removed the steering wheel not will be there hope this helps
Aug 30, 2014 | 2000 Mercedes-Benz SLK
How do i repair this
Hi, You'll need to replace the ignition barrel and switch. If you go to a dealer, there is a possibility of keeping the same key. Regards John .
Aug 19, 2014 | 2006 Ford F-150
Which F key do I use to reformat my Acer Aspire One A 150 netbook?
Hi and welcome to FixYa!
The first thing you need to do is save all of your pictures and files that you have on your computer to your email or upload them to another account that stores them. When you factory reset an Acer, it wipes it clean of everything you have downloaded on it. THIS IS PERMANENT ONCE FACTORY RESTORE IS DONE.
Turn your computer off.
Restart your computer.
When the Acer screen comes up, press and hold Alt+F10.
Keep pressing F10 repeatedly while keeping the Alt button pressed down.
You will be asked how you want to reset your computer.
Press Factory Restore.
This may take up to an hour.
If you are asked to enter a pass code, enter your pass code or 000000.
Hit okay.
If this solution was helpful, please rate!
KittyTech
Nov 15, 2010 | Acer Aspire One A150-1006 Notebook
HT-Z110 DVD player, does not start whe the switch is put on, it just appears a sign PROTECT on the screen, then it gos off, I'd like to have more information about this set, specially the squematic...
Look at getting a replacement power supply module for the unit. Some units had problems with capacitors failing and keeping a unit in protect mode. I use www.shopjimmy.com for whole working replacement boards. You may be able to do the change yourself if they have a part. Average boards cost $150-200
May 04, 2010 | Samsung UN55B8000 55 in. LCD HDTV
The handle on our Marcato Atlas 150 keeps getting stuck and is difficult to pull out for storage. Any ideas?
I opened the rollers to the widest setting (Zero), and placed a folded business card between the rollers. I then turned the dial down so the rollers were "pinching" the card, and while keeping tension on the dial to gently squeeze the card, I gently shook the handle for a few seconds and it came out!
Jan 12, 2010 | Atlas Translator Marcato Atlas 150 Handle...
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Dec 18, 2009 | Raymarine St 4000 Wheel Drive E12093
In my sisters 2004 crown Vic headlights quit working. Have to pill up on light lever continuously and then the brights work. the problem is intermittent some times working and others not. Mechanic replaced...
had same problem. I replaced the master switch and also the turn signal indicator which also controls wipers and wiper motor,hi and low beams, window squirter, located on left side of steering column.works great now but may cost you 150 more dollars.
Oct 23, 2009 | Ford Crown Victoria Cars & Trucks
I bought a easylink advisor and I want to Know if I have to recorder this thing to the ordinator for running my lap-top after
Hi pingouine89, it does not hurt to write down your settings especially if you setup security settings. You check your settings any time by doing this. Open internet explorer. In the address window type 192.168.1.1 than press enter. A pop-up windows will open. In the password window type in admin & press enter. This will bring up your settings, but it will not show you your security settings password if you set one up. (as suggested write it down & store it on a floppy disk for safe keeping.
If I can be of more service, just ask.
Mike
Mar 31, 2008 | Computers & Internet
Raymarine RL70CRC GPS Receiver Logo
169 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
