Question about Bulova Watches
I have a Bulova Caravelle mens wrist watch case number C877548. I have to replace the battery but I can't figure out how to get the back of the case off. Thanks
Hi. If you take a tiny screwdriver (one that you might use to screw a screw into an eyeglass and run it gently around the back you will feel an indentation where you can insert the tip and pop open the back. The battery is easy to access but trying to get the back back on is the problem! Good Luck.
Posted on Nov 22, 2009
I need to replace Battery for C969908 Bulova Carvelle ? How, where, what's the stock number?
Take your Bulova Caravelle to a jeweler who, for a reasonable sum, will replace the battery.
Dec 03, 2016 | Bulova Watches
Time to replace the battery, but cannot manage to remove the back cover. Any special tricks? I'm familiar with using sharp knife blade to do this, but it's not working. Thanks!
You defenately need a watch case opener.
It can be more than difficult to open a watch case with a sharp knive/screwdriver without destroying it.
A case opener can be the only solution.
Otherwise you'll have to bring your watch to a professional to get the battery replaced.
http://www.watchtools.co.uk/watchtools.html#opener
Good luck
Aug 23, 2011 | Bulova Caravelle Strap 43C20 Watch for Men
Please tell me where the serial and model numbers arre on a Bulova marine Star 100m. men's copycay513@gmail.com
Most of the time you can find the serial and or model number on the first link that is attached to the case of the watch on the back. Often there is a serial number on the back of the case itself. If not in any of these locations you may have to open the case and look on the inside of the case. Be careful with opening case, if you're not comfortable opening the case yourself take it to a reputable jeweler.
If there are no serials on the watch it is probably a knockoff or replica.
Hope this helps.
Feb 27, 2011 | Bulova Marine Star 96G30 Wrist Watch
I NEED A MANUAL FOR THIS WATCH
If you go to
http://www.bulova.com/brands/caravelle/product.aspx?origin=sku&sku=43C11&brand=caravelle
(paste this link into your search engine box) and you will arrive at the Boluva web site. There you will see a box lebelled "operating instructions'' which you can download.
Jan 21, 2011 | Bulova 43C11 Caravelle Strap Watch for Men
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
Aug 02, 2010 | Accutron Swiss Watch by Bulova 26B44
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
Mar 05, 2010 | Accutron Swiss Watch by Bulova 26B44
I have a Caravelle Bulova watch #48G33 and I need to change the battery. I took it to a jeweler and he mess up the back and told me he did not have a battery that fit. I think he was unable to get the back...
Hey there !
if the back has a notch on the top left of the cover (right underneath to what would be 10'oclock position), it is a 'Pop-up'. But if the watch has 6-8 notches on the back plate of the watch its a screw-off.
Its really hard to say what battery size it would take due to the fact that each watch has a different operating mechanism and its hard to determine that from the model number.
Dec 23, 2009 | Caravell Bulova Caravelle watch
How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Jul 09, 2009 | Bulova Watch
Caravelle by Bulova watch strap adjust
You need to push the pins out in the direction of the arrows. Then take out one link from each side. Put the pins back in the same way they came out, with the slot pointing the same direction as before.
Feb 25, 2007 | Caravell Bulova Caravelle watch
Watches Logo
728 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
