Help where can i finde the internal fuse?? thk CP-RS55 Multimedia Projector
  • 1 more comment
  • mwex112 Jan 08, 2009
    I have the same problem. Can you help me in opening up the cover. also where can I get a net fuse assuming that is the problem. Thank you
  • Anonymous Mar 09, 2009
    how those the fuse looks like?
  • Bgoff May 07, 2009
    no one can tell us where to get the fuse.
    Can't seem to find a replacement fuse for InFocus LP120 DLP.
  • 563 Answers
Hi there
The internal fuse will be located on the Main Powersupply Board ( the one that takes in the AC socket )
Posted on Sep 26, 2008
How to reset the filter timer of HITACHI CP-RS55 ?
(1) While the projector running, press the MENU button to open the menu.
(2) Choose "OPTION" , then press ENTER button.
(3) Choose "FILTER TIME", then press and hold the RESET button for 3 seconds.
(4) Choose "RESET" .
Feb 25, 2011 | Hitachi Performa CP-RS55 Multimedia...
I have a Hitachi LCD projector model No. CP-RX70. When I connect with my laptop (Compaque) and start both then only starting window XP message appears through projector and laptop works normally but again...
The setup is not correct. Check the requirements of the projector, (size, refresh rates etc.) and set the laptop up accordingly.
You will se the XP Screen because the laptop hasn't loaded any drivers yet and the screen is low resolution.
Hope that helps.
Dec 06, 2010 | Hitachi Performa CP-RS55 Multimedia...
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
NO power, no lights, possibly there was a flash before it went of
The internal fuse is normally located very near the power plug socket and usually a Buss glass fuse, rated 5 amps? If you get to it, check the metal end for the rating.You have to remove the top cover to get at it...remember, the problem could be the fuse--or the power supply section has failed.--Rick
Feb 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Instruction Manual
Pls try here. You would need Adobe Acrobat Reader to open, view and print this type if file.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
My CP-RS55 Projector Doesn't Work??? No Light?
Hi there
If the unit is brand new , they should replace it under warranty.
This is most probably a faulty Powersupply / Fanboard !
Apr 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
No power lights
ok " could be a internal fuse, or bad transformer
Id check for a fuse first
Nov 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
Hitachi Performa CP-RS55 Multimedia... Problem
ok " sounds like you have a short, thats why it's blowing fuses
Nov 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
Internal fuse
HI
Check that you use another power outlet,see that the power cord pins are clean,and not burnt or use a new cord,the connection at the projector makes a GOOD connection with the new cord.
You will need a multimeter to check if there is voltage at the inside of the projector cord connection.You will have to remove the internal fuse before you check the the voltage inside.If all looks good then you will have a fault on the circuit board-shorted component on power supply side or further in on the circuit(need an electronic tech for this).Hope this helps--Jay
SAFTEY FIRST ALL TIMES--NOT SURE DO NOT DO IT
Oct 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
667 people viewed this question
jasbo
jasbo
