Question about GE Advantium 120 Convection/Microwave Oven
Turntable GE Advantium 120 turntable not turning. Possible cause?
  • GE Master
  • 5,568 Answers
Remove the glass table and watch the drive spindle to see if it is turning when the unit runs; just put a cup of water so the magnetron is not without load, they can be damaged otherwise.
If it doesn't turn, gently try to turn the spindle with your fingers.  If it turns manually, then the motor has failed. If it doesn't, then some foodstuff has managed to freeze the spindle.
In the latter case, pull the plug from the wall, use some foaming cleanser (it's less wet) and try to get some under or around the spindle. Let it soak overnight, then try to turn the spindle with your fingers again.  If it's now free, mop up and remove as much of the remaining cleanser as you can, leaving the table out, put a cup of water or preferably a bowl with more volume, in the unit, let it run for some minutes to try to dry the rest of the cleanser out.
Put the table back in to see if it will now turn.
If this doesn't work, it will be necessary to replace the motor.  Since this is a unit I don't know, I can't predict if it is a DIY project or not and the dealer may ask an unrealistic price for the replacement.
Posted on Sep 11, 2008
Turntable does not turn, Replaced Rotating ring assembly still not turning?
It may be the servo motor that powers the turntable or the belt has snapped or come off. It is unlikely that you can get to the motor as the case is fitted with security screws. If so, you will need to take it to a service engineer.
Mar 18, 2016 | GE Advantium 120 Convection/Microwave Oven
Advantium arc
Unfortunately there is nothing you can do but to buy a new microwave oven Once it arcs it causes burns on and in the parts and most times cleaning does nothing
Sorry, good luck
Jan 24, 2014 | GE Advantium 120 Convection/Microwave Oven
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
My advantium lights, turntable turns, timer works, appears to be working as usual, but does not heat..
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Sparks coming from underneath turntable.
check for black spot on support for turn table and floor of unit, sand them back to the metal serface and paint if cavity is not stainless steel, if turn table is not turning replace the motor as this could cause this issue as well.
Feb 04, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Advantium Microwave: No rotation
The screw heads on rear of GE microwave is special, what do i need to ask for to remove them.
Thanks Gayle
Mar 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Sensor error and periodic beeping for Advantium 120
If the internal cooling fan does not come on when you're microwaving, the magnetron will overheat and the thermal cutout will be tripped, causing the oven to go dead until it cools back down.
If this happens more than a few times, the magnetron can be damaged.
If the turntable is not turning (assuming it's not set to be off) when you're microwaving, then the problem lies on the relay circuit board (sub PC).
If the turntable is wokring and the fan is not, then the fan motor or wiring is at fault.
At this point, with such odd problems, I recommend that you contact GE customer service for your nearest GE-authorized service center
GE Customer Service is here.
Good luck.
Jan 10, 2009 | GE Advantium 120 Convection/Microwave Oven
Arcing
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
527 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
