Question about Whirlpool Dishwashers
Hi, we have a Whirlpool dishwasher and the er4 fault has appeared and it keeps sounding, is there a way we can reset the fault Thank you
    Genius:
  • 1,239 Answers
Hi, we have a Whirlpool - how-to-repair-a-dishwasher-1.jpgOn many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
thank u...rate it
Posted on Sep 11, 2008
Cannot change programme
Sounds like a bad console Craig
Apr 07, 2014 | Whirlpool ADG8200 Dishwasher
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Whirlpool dishwasher model# DU915PWSS0 S/N# DE3960705 reset procedure? The problem: dishwasher will not start the only buttons that will light up when I push them are heavy, rinse only, and heated dry. I...
  • Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
  • 3
    Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
  • 4
    Repeat step 3. This will reset the dishwasher.
  • May 11, 2011 | Whirlpool Dishwashers
    Hi, on my WAE8987 Washing machine, the fault code 'F07' keeps coming up, can anyone help please? thanks
    Bauknecht are built by Whirlpool.
    F7 on Whirlpool means flow meter failure.
    Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
    To reset try turning on the power and holding the start button and the + and - buttons at the same time.
    Dec 01, 2009 | Bauknecht Dishwashers
    Whirlpool dishwasher gu1500xtls2
    HI, this is a control fault and you can confirm failure by shutting off the breaker switch or unplugging for 5 minutes. if the unit continues to malfunction after the 5 minute reset, you will need to replace the electronic control board.
    Electronic Control board part number----8534866
    May 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
    How do i reset my dishwasher adp4504 . i have kept my finger on the start button but just keeps on flashing
    Hi!
    Try pressing sani rinse and heated dry back and forth. All the lights will light and it will reset itself.
    Please see this link for more information---
    Whirlpool dishwasher reset
    Please rate the solution if found useful.
    Thanks
    Rylee
    Feb 24, 2009 | Whirlpool 18 in. ADP530 Free-standing...
    Sienens microwave HFT879 fault
    Exactly the same problem over here, but after our house was hit by lightning, so not really surprised about the cause of the problem. If you look closely, you can still see the displays on a very low light level. I can still choose a microwave program, turn the time etc, and see the time changing, but start won't just just work.
    m.de.man att zonnet.nl
    Jan 11, 2009 | Siemens HF87950GB Convection Microwave...
    Whirlpool Dishwasher power surge results in flashing clean button
    I'm not sure what the sequence would be on your particular model as Whirlpool dishwashers can differ in operaiton. However, if you remove the lower kick panel under the dishwasher door, there should be a tech sheet either directly behind the panel, or tucked inside the door. The tech sheet will list all troubleshooting tips and any fault codes that the owner/operator's manual does not list. This is the SAME sheet the repairman will reference when they come to your home on a service call. Please let me know if you still require assistance. I hope this helps you.
    Oct 22, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
    Whirlpool dishwasher not working
    igsanders.. that is a heater fault code. toggle between heated dry and normal until all light light up . press cancel. now ensure door closes without striking cabinet and the unit is level. this fault normally has nothing to do with the heater but rather the nuetral to the door switch which it shares with the heater.it will now operate again.
    Dec 05, 2007 | Whirlpool Gold 24 in. Built-In Dishwasher...
    Dishwashers Logo
    106 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
