Question about Home
Odor coming from bathtub
I have recently noticed a horrible odor emanating from our bathtub inour basement. I plugged the drain to stop the smell, but I realizethat's only a temporary solution. I can still smell the odor in thebathroom, but not as heavily. Someone mentioned that the pipe on the roof that ventsall the gases from my bathrooms could be clogged. Another Internet searchsuggested that my fixtures may not be sealed, and they could be leakinggas. Help, please!!
  • Hot Tip Sep 11, 2008
    I have similar problem the water in the "S" bend evaporates and lets the unpleasant odour thru the pipe.
    check that the odours are not coming thru floor overflow drain as in some older plumbing configuratins these are not fed with water via outlet drain causing the same odours.
    I have to manualy pour water in my floor drain pipes.
  • thejobes Sep 12, 2008
    Thanks, Harvey Master Plumber!! So you're saying that even though the bathtub is the main smeller, it's probably a toilet seal problem? If that's the case, I'll call a pro and have him come and fix it.
    Thank you for your help - it is much appreciated!
What about a dry trap ? has the tub been used in a while, if not run water in the sink,tub and flush the toilit
Posted on Jan 16, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi thejobes
I'm Harvey the Master Plumber
It's been my expirience 99 times out of 100 that you'll find the culprit is a bad toilet to floor seal, better known as a bowl wax. Some handimen can do this replacement but I strongly recomend a pro. It is certainly better than the alternative. If you're unlucky to be that 1% and the bowl wax dosen't work then your problem is a cracked or brocken pipe somewhere.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 12, 2008
  • Harvey Goldberg Sep 12, 2008
    Thank you for your response.
    Yes, I'm sorry to say, this may be best diagnosed by a pro.
    Thank you,
Bad smell from heating system
I would guess so because there should not be an odor coming from your vents and if it is worse when the heat is on there's a chance something literally crawled up there and died! I always wanted to say that not referring to peoples butts. lol But all kidding aside. You would be surprised at the little critters that can find there way into your venting system. Or just organic material that has gotten in there somehow and decayed. Best of luck tracking down those oderiferous emanations.
Dec 20, 2013 | Eagle Vision Cars & Trucks
We have a rinnai convector gas heater and when we turn it on it fills the room with a horrible gassy smell.
There are a couple of things that can cause this odor. But, being sure it's really a gassy odor is more important. It must smell like "rotten eggs" to be gas. If that is the odor you're smell, turn the heater of and contact an authorized Rinnai dealer for service.
If however the odor does not meet the "rotten egg smell", there are other things that cause the odor, but it's not really from the heater.
If you have painted or stained within the last 2 weeks, the heater has picked up the odor of the fumes (which you probably didn't notice) and has made time 50 times worse. The same holds true for carpet cleaning or new carpeting odors. If this fits the scenario, discontinue using the heater for a week or two until the odors subside. In the meantime, if weather allows, air the house out. Also, remove and clean the heaters filter, before restarting the heater,
I hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
This will be our third winter in our home, and for some reason this years when we run the heater it smells. The smell is similar to a stinky bathroom odor (that's the best way I can describe it). I...
Contact your Gas company tell them you have a foul smell coming in when you turn on the heater. They typically wont charge for a technician to come out and inspect the heater for you.
Nov 15, 2010 | Heating & Cooling
Clothes come our smelling bad
Run a load empty on the hottest setting with a cup of bleach.
Then, after finished using the machine each day, leave the door open for a few hours to allow the rubber seal to dry.
Jun 30, 2009 | Zanussi FLA1001W Front Load Washer
For years we have been dealing with sewer gases coming into the house. Sometimes it would get to the point of backup or the toilets would not flush. The city will come in and put the snake out well onto...
I once solved a problem like this -- it was the bathtub drain which had no P-trap on it. This could fit your situation -- when the drain is snaked there is less waste to produce odor. When the line gets sludge in it again, the odor returns.
No p-trap means the odor can come up thru the line with nothing to stop it.
Has anyone checked to see if all fixtures have p-traps? One way to investigate, if you can't see the plumbing, is to run drain water somewhere in the house and see if you can hear the drain water running when you put your ear to each of the plumbing fixture drains.
You would probably have to run the drain water from a fixture which is "in front of" the fixture you are checking so the water would run past it on the way to the main drain.
Apr 29, 2009 | American Standard Cambridge 5' Americast...
Foul odor coming from kitchen sink/dishwasher area????
Hi Jenny - I had a terrible smell coming from under my sink, and I too thought it was a dishwasher/garbage disposal drainage issue. I used vinegar, baking soda, bleach and hot water on a daily basis. When I cut out the wallboard from under the sink and the smell got even worse, however, there was no sign of any water leaks or evidence of a dead animals. Come to find out, when I had a "friend" cut out a pass through from my kitchen (above the sink) into the den, he cut the pvc exhaust pipe and didn't re-route it nor cap allowing the fumes to escape outside via the attic. Thus, the fumes had no place to go other than down. The smell confused me because I thought it was rotten food or most likely a dead mouse trapped between the wall. The smell was actually causing me to get headaches. It's been almost 24 hours that this was repaired and I already can "smell" the difference. I hope this helps! Good luck.
Mar 30, 2009 | Tappan MDB531RF Dishwasher
Odor from toaster
ozone smells like fresh sweet air ( same smell as after a lightning strike )
what you probably have is the smell of melting plastic from wires in the toaster
Apr 06, 2017 | Kenmore KTES4 4-Slice Toaster
Smelly refrigerator
HI.
i guess u will benifit from this link
plz rate this post
click here
BEST REGARDS
Aug 13, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Washing machine has burning odor
smell usually come from motor over worked, possibly under powered( check to make sure you have a110 volt, supply and not perhaps 100, possible bad start capacitor eminating small as well, its mounted either to the motor itself or on the back wall just below the water valve assy
Apr 21, 2008 | Washing Machines
Home Logo
636 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
