Question about Asko Washing Machines
Asko front washer is leaking water from the bottom right side
  • 1,239 Answers
  1. asko front washer is leaking - how-to-repair-a-dishwasher-2.jpgDishwashers are usually protected from overfilling by a float switch. This switch is located in the bottom of the unit. Here's how to check and replace it:Step 1: Open the door and remove the bottom dish rack. Check to see if the float valve is stuck. If it is, clean away food debris around the float. With a screwdriver handle, lightly tap the top of the float to free it.Step 2: If tapping doesn't work, remove the lower access panel and locate the bottom portion of the float and float switch. Test the float switch with a VOM set to the RX1 scale. Unscrew one electrical lead wire to the switch terminal, and clip one probe of the VOM to each terminal. If the meter reads zero, the switch is not faulty. The trouble is probably in the timer. If the meter reads higher than zero, the switch is faulty.Step 3: Replace the switch with a new one made to fit the dishwasher. The switch is held to a mounting bracket with screws; remove the screws to get the old switch out.Step 4: Connect the new switch the same way the old one was connected
  2. thank u ;;;;rate it
Posted on Sep 11, 2008
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
F2 and all panel lights flashing part way through cycle. Machine will not switch off unless you switch power button off
You have water in the bottom pan.Turn off power Remove bothe front and rear lower panels and dry out pan with a towel after tipping water from pan. Turn on power and try operating the washer and look for water leak. It could be coming from a number of places. The repair will be what ever is the cause of the leak. F 2 = water in the pan. Hope this helps. Rgd Robocam
Mar 07, 2011 | Asko D1876 Dishwasher
Asko W6021 Front Load Washer error detected "F3 Outlet Blocked". How to solve this problem?
The drain access is at the bottom left of the washer. Insert a screw driver in the right side of the cut-out and and gently pry open. Open the drain pump. You will need a small container and a towel to help catch the water that will be coming out. After letting all the water out, clean out any objects in the drain pump. After cleaning out drain pump, put everything back together and restart washer.
Feb 05, 2011 | Asko W6021 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black can get a book from
Jun 15, 2010 | Asko W6021 Front Load Washer
Hello, I have an ASKO Washer model W6461 and I notcied a puddle (1/2 cup) under the front right part of the machine after running it once. How do i get the service manual for this machine so i can...
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the can get the book from
Jun 15, 2010 | Asko W6461 Front Load Washer
Leaking from base of machine
Probably got a sht gasket. Check under the washer to see where the water is comng from. This is a common problem.
Nov 15, 2008 | Asko W6441 Front Load Washer
Asko D1706 No water in the sprinklers
You can get access to the base from behind the dishwasher ,you will find about 6 screws to remove the back panel at the bottom to see if its leaking.
Feb 17, 2008 | Asko D1706 Built-in Dishwasher
Asko Washer leak
Remove the bacpanel, and locate the leak. Be careful for moving parts, and electricity.
It may leak from the pump or from a hose or so.
Jan 15, 2008 | Asko W6441 Front Load Washer
Washing Machines Logo
428 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
