Error code 13.000 reported on my Colour Laserjet 2420, in error log
4 Suggested Answers
dapidc
  • 111 Answers
SOURCE: hp colour laserjet 4600dn, 51.2Y error...how to solve that?
From Woody Friesen:
Did the printer have a rough ride? HP's service manual suggests this to be a laser error on the yellow laser scanner, though these printers usually withstand shipping without any problems. Just for grins, if you can get the printer to get to READY again, run the printer through a complete calibration (from the control panel: Configure Device/Print Quality/Calibrate Now). The DC controller circuit board is also a possibility, but given the error code popped up almost as soon as you plugged the machine in suggests the yellow scanner has suffered some sort of mechanical damage from the trip. If the calibrate routine doesn't remedy the problem and you want to be sure, you could do the major disassembly required and swap the yellow scanner with the scanner for another color in the printer and if the error code changes to 51.2M (magenta), 51.2C (cyan) or 51.2K (black) (the code will reflect which scanner you exchanged with the one in the yellow position) you'll have confirmed the scanner is the problem, or if no change, then the DC controller is next in the chain.
Posted on Dec 24, 2008
  • 14 Answers
SOURCE: hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: Hp laserjet 2420 service error 49.0665
This is either a firmware error or a memory error.
Try downloading and installing new firmware from HPs website.
Instructions are on the site.
Posted on Oct 14, 2009
HP Laserjet 2420 error 41.2
hi i found the problem in hp laserjet 2420 printer error 41.2
Mar 19, 2012 | HP LaserJet 2420 Printer
I have a HP Laserjet 2420 and show error code 41.03.00
Un expected paper too lengh, check papers are loading one by one or more then one at a time loading in side?..If multi papers are loading, replave separation padClean all paper path sensors..
Aug 19, 2011 | HP LaserJet 2420 Printer
Laserjet 2420 10.00.00 supply memory error
this is a toner chip error, I guarantee you replace the toner and it will go away...Click Here
if you just want to test the theory, take the old used toner and put it in the machine, the error will disappear... if this helps please mark fixya...
Jul 14, 2011 | HP LaserJet 2420 Printer
Hello....i have HP LaserJet printer 2420. when I print it gives me 52.00 error and not printing at all
52.00 error is not good.
If you tried powering off and on and that didn't work, a tech is going to have to look at it.
Problem could be the laser/scanner or the engine control board(ECU)
May 26, 2011 | HP LaserJet 2420 Printer
Sep 29, 2009 | HP LaserJet 2420 Printer
My HP LaserJet 2420 has disappeared from my "printers" control panel. The printer is connected via USB. I have swapped cables and have tried to install it on another computer with NO result. There are NO...
There might be a problem with your computer as well. Try printing with paralell cable to make sure the interface works at all. If the patalell-port works fine, try updating the printers firmware. Still problems ? Try with a different computer. If if works fine with another computer, then you know theres something wrong with your first computer. Good luck.
Aug 10, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Hp 2420 error 49 3c1a
If the printer is displaying 49.xx error message, followng the following document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
Upgrading the firmware should resolve the issue.
Please let me know one you perform the above upgrade.
- Nikhil
Nov 20, 2008 | HP LaserJet 2420 Printer
Error code on hp 2420
It's a communication or hardware error.
It's best if you update your firmware. Get the files from the link below...
HP 2420 Firmware Updates
Error code
This is a ram dimm error try changing dimm(s) to other slots(s) please ask for more info if required
Oct 31, 2008 | HP LaserJet 2420 Printer
HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Apr 15, 2008 | HP LaserJet 2420 Printer
321 people viewed this question
jasbo
jasbo
