AIRBAG IGNITER FAULT AUDIO A4 CAB - Audio Players & Recorders
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
Confirm correct or incorrect operation of all or any steering wheel controls. If any of those are delinquent the clockspring located inside the steering wheel will need to be replaced. If the controls (if applicable) are all operational then the airbag module will need to be replaced. Remember to ALWAYS remove battery power and disconnect all power sources before servicing any airbags or related components. Good luck and be safe.
Posted on Nov 13, 2014
Hi. What does Fault codes 9CFF and B1CFF means on a Mercedes C180 204. Its on the Airbags
9cff is a fault in the self tightening seat belt igniter circuit. Has the car been in an accident? The seat belts must be replaced after a collision if this code appears
Sep 21, 2016 | Mercedes-Benz C-Class Cars & Trucks
Code 65535 what does that mean
How do i remove t-mobile content lock with out credit card or by going to t-mobile shop.
Apr 05, 2013 | Cars & Trucks
Airbag light won't stay off
airbag control module may need replacing
Apr 03, 2013 | 1999 Audi A4
1996 golf vr6 airbag light on
I think you will find the Airbag is defective. Make sure you disarm this system before you touch anything, it can kill you.
May 25, 2012 | 1996 Volkswagen Golf
The airbag light on the dash of my 2003 Audi A4 keeps coming on. How do I fix it myself?
its unfortunate but u are not able to. Your vehicle has multiple computers controlling all the electrics.
When a warning light comes on such as your airbag light or an engine light it is usually because of a fault.
if there is a fault and you ignore it and just cancel the light, then in an accident the airbag might not deploy. which would not be a good end result.
i would take it to a mechanic who has a scan tool to find the code that is causing your airbag light to come on, then fix the issue.
this will solve your airbag light problem and keep you safe on the roads as well.
cheers
Jan 11, 2011 | 2003 Audi A4 Cabriolet
1999 audi a4 airbag light just came on and stays on?
When the airbag light (SRS) is on or blinks it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called the clock spring contact, a coiled up ribbon electrical contact that turns with the steering wheel while maintaining a mechanical connection to the airgag mounted on the steering wheel, to replace this part you must disarm the airbag system and remove the steering wheel, this requires a special steering wheel puller tool and that you disarm the airbag system before you start the work, to do this disconnect the battery negative cable for 1 hour prior.
Jan 25, 2010 | 1999 Audi A4
Air bag light started coming on /dash constantly
the likely fault is the cables running to the seatbelt pre-tensioners under the drivers or passengers seat in the front of the car.
This may be simply the plug and socket have become seperated from sliding the seat back to clean, a common fault, or the airbag "clockspring" connection unit in the steering wheel has a broken ribbon cable inside the column housing.
To see if its the airbag clockspring, buy a 4 ohm resistor from maplin or radio shack, disconnect the battery on the car, unplug the airbag in the steering wheel and connect the resistor across the 2 contacts in place of the airbag, reconnect the battery, if the light goes out the clockspring is the fault, if not its the SRS system wiring under the seats.
Jan 10, 2010 | 2000 Audi A4
Airbag stays on audi a4 1904
There is a fault in the airbag system. Needs to be put on a scan tool at a dealership to find out what is the exact fault.
Jan 01, 2010 | 1999 Volkswagen Beetle
A4 cabriolet airbag light
just give the wires under the seat a wiggle and see if goes out ,fairl common problem this on a lot of cars
Aug 14, 2009 | Audi Cabriolet Cars & Trucks
Airbag control module, airbag light on constantly
you need to send me the airbag control module to lebanon at my adress raja mjaes-dhour el chweir -raffoul mjaes building and my e-mail is class_c_a_r@hotmail.com and i can fix any airbag ecu or any airbag problem that i can trough the web
Jan 20, 2009 | 2000 Audi A4
165 people viewed this question
 Grubhead
Grubhead
