Question about Karcher 2500 PSI Pressure Washer
There is no pressure - Karcher 2500 PSI Pressure Washer
  • 3 Answers
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace about a $5 (maybe) part, and it took about 5 minutes.
Posted on Sep 11, 2008
What is the meaning of blood pressure 235/100
If it really is 235, you need a hospital straight away. That is embolism, stroke and heart attack pressure.
Should not be more that 140/70
Your blood pressure is 235 over 105? - BloodpressureOK.com
bloodpressureok.com/reading/235-over-105/
But regarding your systolic (upper) value your blood pressure is rather: Way too high - Hypertension Stage 3 / Hypertensive crisis. If you are getting two different ...
Hypertensive Crisis: When You Should Call 9-1-1 for High Blood ...
www.heart.org/.../HighBloodPressure/GettheFactsAboutHighBloodPressure/Hypertens... Jan 18, 2017 - Know the two types of HBP crisis to watch for. A hypertensive (high blood pressure) crisis is when blood pressure rises quickly and severely.
Blood Pressure: 225/132 ' What Does My Blood Pressure Reading ...
https://www.caring.com/charts/blood-pressure-225-132 Learn what your blood pressure of 225/132 means. Find out if your blood pressure levels or readings are normal, too high, or too low -- and what you can do ...
blood pressure above 280 - High Blood Pressure / Hypertension ...
www.medhelp.org > Communities > High Blood Pressure / Hypertension Jun 11, 2015 - Has anyone experienced blood pressure of over 280 close to 300? ... My mother just died (less than a week ago) after her blood pressure ...
Blood Pressure Chart - Normal Blood Pressure Range - Vaughn's ...
www.vaughns-1-pagers.com/medicine/blood-pressure.htm Normal blood pressure range chart, with comments about each blood pressure level. High, normal and low blood pressure are defined. blood pressure 235 100 Google Search
Jul 09, 2017 | The Health & Beauty
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
Technique model 89759. Where can I get a user's manual?
pressure cooker manual & recipe booklet library ' hip ...
www.hippressurecooking.com/pressure-cooker-manual-library/
Dec 14, 2015 - Free downloadable copies of pressure cooker instruction manuals for stove top ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet .... SunbeamPressure Cooker Manual; Technique Pressure Cooker (see Deni); T-fal ... Tower (see Fagor for similar models); Tramontina Pressure Cooker Manuals ...
Technique Oval Talking Electric Pressure Cooker Manual ...
www.hippressurecooking.com/technique-oval-talking-electric-pressure-c...
Oct 7, 2009 - Technique Oval Talking Electric Pressure Cooker Manual. 44 ... ForTechnique Pressure Cooker model numbers: 99800, 99801, 99802, 99803, ...
Technique by Cook's Essentials Digital Pressure Cooker ...
www.hippressurecooking.com/technique-by-cooks-essentials-digital-pres...
Oct 18, 2009 - For Cook's Essentials Model Number: DYB350 Please wait a moment for ... Technique by Cook's Essentials Digital Pressure Cooker Manual.
Jan 19, 2016 | Home
Do the low and high settings mean 10 and 20 pounds pressure
It depends on your pressure cooker brand - each one has a different setting. For pressure cookers that reach 15psi (pounds per square inch) the high setting would be 15 and the low setting would be 8 pounds of pressure. For electric pressure cookers the high pressure is generally 12psi the low pressure setting is generally 6 psi.
FYI: No domestic pressure cooker reaches 20 pounds of pressure.
More info about pressure here:
http://www.hippressurecooking.com/pressure-cooker-psi-faq-the-stuff-you-didnt-think-to-ask/
Oct 14, 2015 | Home
My blood pressure is 110/95 and my heart rate is 124/bpm. I am pregnant what does that mean?
110/95 Blood Pressure
Is 110/95 Good Blood Pressure or High Blood Pressure?
There are two parts or two separate numbers referred to as blood pressure: Systolic/Diastolic. If the blood pressure is 110/95 (110 over 95), it means that the systolic pressure is 110 and the diastolic pressure is 95.
110/95 blood pressure can also be read as 110/95 mm Hg, or 110/95 millimeters of mercury. The 110 mm Hg Systolic refers to the pressure in the arteries when the heart beats, and the 95 mm Hg Diastolic is the pressure in the arteries between heartbeats.
When determining if 110/95 is a good blood pressure, we looked at the American Heart Association's blood pressure chart.
Blood Pressure Systolic Diastolic Normal Less than 120 Less than 80 Prehypertension 120 - 139 80 - 89 High Blood Pressure
(Hypertension) Stage 1 140 - 159 90 - 99 High Blood Pressure
(Hypertension) Stage 2 160 or higher 100 or higher Hypertensive Crisis
(Emergency care needed) Higher than 180 Higher than 110
For 110/95 to be good, both numbers must fit into the "normal" category above. Otherwise, it will fall into other categories of High Blood Pressure.
Systolic reading of 110 is in the Normal range.
Diastolic reading of 95 is in High Blood Pressure (Hypertension) Stage 1 range.
Therefore, 110/95 is High Blood Pressure (Hypertension Stage 1).
Aug 05, 2014 | Veridian Healthcare 01-539 SmartHeart Arm...
I have a new 1 hp utiltech pump and a new. Precharged tank with 34 psi in it now. When i prime the pump the pressure goes right to 25 psi and i can hear some water moving . When i open the shut off valve...
The 34 psi of the pressure tank sounds high, but it depends on what the cut-in pressure is set at in the pump pressure switch. Typically the pressure switch is for 20-40 psi or 30-50 psi. To establish what the pre-charge of tank should be , you need to establish what the pressure switch setting are (i.e 20 - 40 psi , etc.) Run the water and watch the pressure gauge and note at what pressure the pump comes on. The pressure tank needs to be pre charged 2 -4 psi below that cut-in pressure. So if the cut-in pressure is say 30 psi, then the tank needs to be pre charged to 28 psi.
To pre charge the pressure tank, turn the pump off. Drain the pressure tank of water to relieve all pressure in the tank. Then check the pressure of the tank at the air valve. Set the pressure to 2 psi below what the cut-in pressure is.
If you adjust the pressure switch, say from 20-40 to 30-50, you will need to go through the procedure of re adjusting the pressure in the tank. I hope this helps....
May 21, 2014 | Plumbing
What is the m button for
Hope this helps you out
Sep 19, 2011 | Health & Beauty
Why is the pump cutting in so much
Check your water pressure tank air pressure, turn off pump, drain off all water pressure and using a air pressure gauge check pressure at the schrader valve on the water pressure tank. It should be 2 lbs below pump cut-in pressure, they come factory charged at 30 PSI...works for most residential systems. Most likely you have a bad bladder in pressure tank.
Other possibles are a broken line between pump and pressure switch/pressure tank or bad pressure switch.If you have a pressure gauge on the water system(should have one near pressure switch) see if it is cycling at the right points if it is the switch is good. If pressure is dropping with NO water uasge in house you have a leak.
Most likely a bad pressure tank bladder is the problem.
Oct 24, 2009 | Jet Plumbing
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
Aug 27, 2008 | American Diagnostic Corp ADC Advantage...
Karcher 2500 PSI Pressure Washer Logo
652 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
