Question about Epson Stylus Photo R300 InkJet Printer
Yellow ink does not come out.
I have an Epson stylus photo R300. I have applied every cleaning procedure and nozzle check possible. The yellow still doesn't come out. In the Head alignment adjustment printout the black works but for the color alignment printout nothing shows up except the black numbers. Do I have to try to blow with a straw the yellow nozzle? I have tried that - it does not work. I wanted to take the nozzle setup out by unscrewing the two screws holding it in to check if something is blocking it, is this a good idea? I have changed the yellow cartridge, but nothing happened. Thank you for your time.
  • everett phillips Apr 24, 2006
    Thank you for your help. I took apart the printer and cleaned it. But I found out that the problem was that I had two bum cartridges in a row. I never had that happen to me. Well you live and you learn, right. Thanks again. I will defiantly use that presager, holding down the ink bottom and turning on the printer trick. Thanks.
  • 513 Answers
Its possible that your printer is fooled to think that the yellow ink level is lower than it really is. not uncommon. Have you changed the different carts on different occasions? You should try resetting the printer. I can tell you that the stylus 500 is reset by turning off, then back on while holding down the Load/Eject button, can't say if it will do the trick on your r300. BTW - epson printers do not like refills or generic - they will clog. I ran across the following cleaning method on the web, it might help you: "Follow this procedure AT YOUR OWN RISK for all I know I may have damaged my printer irreparably, but it does not appear so.) With the power off I manually moved the print heads to the left exposing the pad under the color head. I used several cotton swabs to soak up as much old ink from this pad as I could. I then liberally applied rubbing alcohol to the pad with a cotton swab. About three swabs worth, saturating the pad. I manually returned the print head to *exactly* the same position it was originally in. I turned on the power. This activated the cleaning sequence. (You might also want to press the color head cleaning button to make sure that at least one cleaning cycle runs with the alcohol on the pad.) I turned off the power. Then, while holding down the color cleaning button, I turned the power back on. This activates the self test. By the time the printing of the second sheet of the test was half way completed I had all my colors back."
Posted on Apr 23, 2006
Problem printing yellow.
IIf the cartridges is original epson there is some color (light magenta that is clogged.
if the cartridges is non original check that is with the right order
Apr 23, 2015 | Epson Stylus Photo R300 InkJet Printer
How do you clean the printer head
HiIf you go to control panel..click on printers and scanners...there will be an option under you're printer to do a maintenance check. There are options there to do a head...nozzle cleaner and alignment
Hope this helps youKind regardsMichelle
Feb 23, 2012 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 is broken
remove the colored not detected then clean the chips then take it back again and turn of the power of printer then on again then see again...thanks...
May 09, 2009 | Epson Stylus Photo R300 InkJet Printer
How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Jan 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo r300 printer
those parts are not user-replaceable
call the vendor - check your warranty status
check this link just in case : http://www.epson.com/loyalty
Dec 27, 2007 | Epson Stylus Photo R300 InkJet Printer
R300 - quality terrible and no status monitor
If you're getting gaps in the nozzle checks and cleaning isn't resolving it, it is possible a nozzle is blocked with dried ink. You can get cleaning cartridges which contain a solvent that disolves the clogged ink.
I'll not suggest any brands, but talk to your local friendly computer shop, or do a search. Something like epson r300 cleaning cartridge should work.
When you say the status monitor is greyed out, is this on the computer or the printer? And I'd hope you're not using HP inks... It's an Epson printer ;) But on a serious note, I've not yet had any problems using non-Epson inks.
HTH,
Neil
Nov 27, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
735 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
