Question about Sony BM-87DST Desktop Cassette Transcriber / Recorder
Tape Difficulties Only TDK tapes seem to work in this machine and we can't figure out why. We have tried other brands with no success.
  • trudysmith Sep 11, 2008
    Sorry, when we try another brand it won't record. Doesn't seem to matter which brand we try. We are using 90 minute tapes.
  • 4,234 Answers
In order to provide any assistance or possible explanations, a little fmore info is required. When you state that other brands don't work, what happens? Also, what size of tapes are you using? 60Min, 90Min? Please post more details about what is and is not working and we'll try to help.
Thanks,
Dan
Posted on Sep 11, 2008
  • ABRsvcs Sep 11, 2008
    Thsnka for the update. One more experiment of you can. Try just playing back another brand that has already been recorded. I suspect that it will play correctly. There is a lever that controls whether or not you can record located inside the unit. If you look at a tape there is a breakable tab that when removed effectively makes the tape unwritable. If the detection lever is out of alignment, perhaps the small differences in the tape housing is not letting the lever enable recording. I can't be sure if this is the problem without seeing the unit though. That is one possibility.
    Keep me posted.
    Dan
I took apart a TDK Video Cassette, and I can't put it back together! I have two small metal cylinders left over, and can't for the life of me figure out where they should go! Please Help!! Thank you
The two metal cylinders are guide rollers where the tape goes in and out of the cassette. If you pick up any VHS tape and press the little button that allows the flap to come up, you should see them.
Sep 10, 2015 | TDK E-HG 120 VHS Tape
Tip
Recommended Media When Using the VRD-MC3
OK, I purchased this device in order to tranfer/preserve stacks of old 8mm and VHS tapes to DVD, quickly, without any desire to perform any editing. I have created several DVD's using the PC and find this to be extremely time consuming, although you have total editing control. I started out with the VRD-MC3 using Memorex inkjet printable DVD+R (16X) blank media (not on Sony's suggested media list) and met with limited success. Was using SP mode in order to get 2 hrs worth of tape on to 1 DVD. After awhlie I started experiencing the dredded "finalize disc" errors, which it couldn't do after sitting there for 2 hrs, and ended up with a few coasters. In talking with Sony, they felt this was most likely attributable to bad media and recommend using a few different brands such as their own, TDK, Verbatim, Maxell. So, I thought I'd try Sony DVD+R (1-16x) blank DVD media and gave it a try, feeling that if it didn't work well with their own media, then it most likely wouldn't do well with any other brand either. I have met with success using this media and had no problems recording tapes that produced coasters the first time. Overall I'm happy with this product but it's finicky and seems to work best if you stick to using Sony's products.
on Nov 21, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
After several years of trouble-free service, it no
I'm hoping your problem is intermittent. Then there's hope.
I've been recording CD's for 10 years and have had similar experience on playback (way after it was too late to procure the source and do it again). My symptom was a nearly constant crackling laid over the audio (constant ineffective error concealment or correction).
I'm a professional Enterprise Data Storage (Tape and Disk) career customer engineer, so I know a little about things and how to troubleshoot Read errors.
I could never pin it down to anything repeatable, like media, but it seemed to happen most on CD's-R-US cheapo discs. The best I can offer is try some different brands (or lots) of media and see if you can find one or two that work.
Feed back what the results are if successful. Many people have the same problems.
Mar 02, 2010 | TDK DA-3826 2-Disc CD Recorder
I have not been able to record LP's. The instructions mention hooking up the cables to the receiver outputs down to the TDK deck. Which outputs? Tape, Aux,? I tried splitting off of my phono outputs with...
your phono outputs are a whole diff ball of wax than aux or tape etc, whole diff signal, all that they should run to is phono in on the receiver. You are using the cd recorder as a tape deck more or less, so use tape out to line in on the tdk, and tape in from tdk output. so..when spinning record, you have receiver set on phono, and the tdk should also be receiving that signal, to playback you would hit tape monitor button on the receiver and hear what the tdk has done, or is doing.
Feb 01, 2010 | TDK DA-5900 2-Disc CD Recorder
Tapes sounding funny
try using a smaller tapetime, the grinding noise your hearing is the gears of the tape take up within the casette not the camera, it seems the Sony tapes are 120mins long and the Sony tapes are heavier than TDK and your spool take up on the camera can't take it. the TDK tapes you were previously using may have been a shorter time than 120minute?...try any Hi 8 60min tapes instead. not the 120, they can be too heavy for the take up spool motor of the camera and all its doing is stretching and winding the cassette tape and unable to pull it with a 120 min cassette
Apr 24, 2017 | Sony Handycam® DCR-TRV250 Digital-8...
No more audio
Have you tried this tape in another machine? Your audio and video heads could be getting clogged. A head cleaning tape may fix it or you may need to have them hand cleaned.
If the tape has been stored where it is potentially warm and humid the tape could have degraded.
Unfortunately even the best quality tapes will eventually degrade as the oxide is slowly removed with every pass of the heads.
If a head clean on your player doesn't work, the best way to attempt to retain those memories is to take it to a professional video duplication place and have it transferred to DVD
Jan 23, 2009 | TDK 10 Pack of P6-120 8MM Tape 8mm Tape
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Camera is a JVC GR-DF470 Video Camera. Problem is UNIT IN SAFEGUARD MODE EJECT AND REINSERT TAPE ERROR 03. I have done this and problem still remains.
I have the same model of camera and the same problem has occurred after two years of use. I am not sure why it happens but checking on other web sites, it may have to do with tape tension and the brand of tape. Up to now, I was using Sony and JVC tapes which worked fine but a recent purchase of TDK tapes seems to have caused this problem.
My fix was to take the tape out and then manually wind the tape a couple of turns by inserting one flat blade screwdriver in the tape lock tab (bottom middle of tape case) and using another to wind the tape. This appeared to fix the tape tension and after loading it back in, the tape and the camera worked fine.
Hope this helps.
May 05, 2008 | Cameras
Tape jammed??
Maybe your blaming the wrong people? Maybe your camcorder has a problem? with the power off, try pushing the eject button and the power button down together for a few seconds, but push down the eject button before the power. If that does not work, you will need to have the camcorder service and ask the servicer to please be kind to the tape as it is important. Good Luck
Jun 12, 2007 | TDK DVM60 60 Minutes Mini DV AY-DVMCLC 5...
Sony BM-87DST Desktop Cassette Transcriber / Recorder Logo
47 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
