Question about Hyundai ImageQuest DPD4210 42 in. HD-Ready Plasma Television
Cant switch it on!
Switch plug on at wall, tv goes to standby then switches itself off. Have to switch off & on at wall at least 20-30 times & use remote until it comes on.
  • Hyundai Master
  • 5,568 Answers
Sounds very much like a main power supply that needs a 'kick' to start up. This is often caused by the loss of value of a capacitor in the power supply, one that handles feedback to start the supply initially and carries the signal to shut it down in case of a circuit fault in one of the areas the supply services. Inadequate feedback will make the supply unable to start properly and more likely to shut down even though no fault condition exists. If I'm right, it will get worse and searching for the problem requires an instrument not found in the average home; a capacitance meter with loss measuring capabilities.
Posted on Sep 11, 2008
ESO NO AYUDA EN NADA
Posted on Sep 12, 2008
Cant switch on my Irion TV
Maybe things will improve if you leave your TV permanently receiving power from the wall switch and do the actual on-off switching at the TV. Your Orion TV draws standby power even when it is off. When you flip the wall switch off there is no standby power
Jul 24, 2013 | Televison & Video
Receiver keeps going to standby
I don't know about the newer receivers but this sounds like an arching OFF/ON power switch that was a problem on Pioneer receivers years ago. I would bypass the switch and see what happens.
1. Unplug unit from wall.
2. Jumper two wires going to off/on switch using alligator clip with insulated boots on clips.
3. Plug amplifier into disconnected circuit breaker/fuse protected AC strip.
4. Plug AC strip into wall outlet, turn AC strip switch ON and see if problem disappears.
Feb 20, 2013 | Insignia 200W Stereo Receiver
I have a 36'olevia HDTV.......it has a detachable power cord and it also has a power switch in back. When I plugged it into the wall,turned on the power switch, and pressed the power button, I got no
The light is likely the standby light if it is on when set is off and goes out when set turned on or changes color when set comes on.
The fact the light is on should rule OUT the main fuse for the set, most likely the problem is the power supply itself inside the set
The Standby supply is part of the main power supply and when set is plugged in and off it runs 7/24.
Have you had problems where the set was "hard to turn on" or you had to try to turn it on several times before it would stay on?
Dec 07, 2012 | Televison & Video
Tv has no display
plug it in and make sure you turn the switch on near the plug and then switch the tv on and press the standby button on the remote if you cant find the standby button then press all buttons on the tv and this should work
Jan 22, 2012 | Samsung Televison & Video
Tvs stuck on standby
Please can anyone help me, my tv switched off itself cant switch it back on. it is on standby mode tried everything in vain the model is Toshiba 28/32YT56
Oct 09, 2009 | Philips Magnavox 20MS3442 20" TV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Stuck in Standby
change the horizontal output transistor .its busted.
Aug 14, 2008 | Bush 5693D 24" TV
'standby' mode and akb error number
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
Aug 14, 2008 | Sony KP-53HS10 TV
TV Switches itself back to standby mode continuously
if your remote is ok then this is due to power supply failure in your tv. either it is loose in oscillator ckt in switching section or it has failed. if not tech person call tech to fix it. not a major problem.
Oct 07, 2007 | Televison & Video
Hyundai ImageQuest DPD4210 42 in. HD-Ready Plasma Television Logo
283 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
