Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Screen Burn In ?
Left a dvd in and the main screen menu created a 6" x 8" blue mark on the screen. Now if watching a channel with wording around that area it also stays on the screen for a while. Can this be fixed?
  • Anonymous Apr 27, 2008
    yep! This tv is only 3 years old. Just replaced lamp. Now I have a purple/blue (prism like) along bottom of screen and a blue haze over middle of screen. Let me know how you fixed it.
    President:
  • 3,130 Answers
Nope Not unless you replace the tubes with the burn in them You have to take off ther front screen and look into the lens while tvs on and you will see what tube is burned worse. Sorry!!! but I have heard of folks equilizing the burned tubes by taking a solid color one at a time (red,green and blue) and keeping on only one color on for 4 to 6 hours one at a time and them all on at a time for a solid white and have seen some pretty good results.. Good Luck
Posted on Apr 19, 2006
DVD bypass code for Jensen VM9216BT
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote,
listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/
screwdriver on it in the upper left-
hand part of the screen.
5: Select Brake bypass to "ON" and hit
the "X" near the bottom of the screen. There is the code.
Jul 16, 2013 | Jensen VM9216BT 7" Touch Screen DVD, MP3,...
Westinghouse HD Flat Screen 1080Pure TV - Shadows
Image burn can be permanent if the image was left on for a long period of time. You can try a pure white screen to balance the screen out. They sell DVDs online that have white screen and other screen correcting images to try an correct the damage done to your panel. here is one linked plasma or LCD both can burn.
best of luck
Thanks
Roety
Jul 14, 2010 | Televison & Video
Burned image on comp 1 chanel
When an image is burnt in to screen it is always there you just dont see it when you watch tv because of the changing video. On some sets you can burn the image out by using a all white screen, from a signal generator or from the service menu, turning the brightness all the way up and letting it play for 24 hours. Here are some websites that have software that is supposed to erase burn-in images, but you would have to hook tv to a computer, unless it can be copied to a dvd and played through a DVD player. Have not used it myself so not sure how or if it works. Be careful not to cause any more damage to screen. A new screen can cost a few hundred to over a thousand dollars to replace. Set should be taken to a panasonic repair shop to try burning it out with white screen approach, so if they damage it they have to fix it.
http://www.sharewareplaza.com/JScreenFix-download_44365.html
http://www.top-shareware.net/lcd.html
http://www.fast-download.info/screen-fix.html
Nov 03, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Jensen player
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
Apr 06, 2009 | Jensen VM9410 Car DVD Player
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Screen Burn In ?
no cure, you can try taking it back but dont be too surprised if they wont accept it. there are loads of warnings about static images being left on projection tv's
May 15, 2008 | Zenith E44W46LCD 44" Rear Projection...
Acer LCD TV screen burn.
Burn in unfortunatly is permanant. It damages the liquid crystals that produce the image.
Mar 08, 2008 | Televison & Video
Jensen dvd not showing
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
Region Code
Loader Version
Model Version
Region Code: 1
Brake Override ON
Macrovision: OFF
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Feb 17, 2008 | Jensen VM9510 Car DVD Player
Hii
This is the way to do it without engaging the parking brake sequence, thus you're inputting the code blindly.
Dec 04, 2007 | Jensen VM9510 Car DVD Player
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
759 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
