Question about Frigidaire FMV157GM Microwave Oven
Frigidaire Microwave FMV157GC
We have an intermittent problem: we close the door and turn it on (manual or automatic). The countdown works, but the oven does not work. We always eventually get it to work by opening the door and hitting the buttons several times, but have never figured out what causes this problem. It only happens in the mornings (after the oven has not been used for some time).
  • 1 more comment
  • jwoodpar Nov 15, 2008
    The countdown works, but the oven does not work. everything else works- heating does not occur.
  • tresecole Nov 20, 2008
    i was heating a cup of water when i realized after about 2 minutes the microwave was silent. the countdown contiuned and the light was on but the microwave wasn't making a sound. my microwave is above my range and when i was inspecting the microwave i noticed some warping to the plastic at the bottom of the door. It's been this way since we moved here but could that be the problem?
  • tonyrome Nov 24, 2008
    everything works but the range does not come start.
I had the problem where the timer continues to count down but turntable doesn't turn, fan doesn't come on and food doesn't heat. Holding the door up worked for awhile but even that temporary method stopped working.
I bought a door interlock switch the cost $23 from an appliance repair place and replaced it myself. It worked like a charm. To replace the switch, you need to remove 3 screws that hold the plastic grille above the door, which exposes the 1 screw that is holding the control panel. Remove that screw and slide the control panel up to remove it. There are three switches left of the panel. Note the middle swich has a different part number so I'm not sure what that one is called. The bad one on mine happen to be the bottom one. The switch is held on by a "pin" and tab that holds it in place. Push the tab and spin the switch on its "pin" past the tab to remove. Reverse your step to put the new one on. I hope this helps.
Posted on May 09, 2009
Microwave ovens use low voltage at high current to heat Magnetron filament.
Reported fault can be caused by poorly conducting Crimp joints on spade connectors to Magnetron.
Remedy is to solder wire from filament transformer to spade connectors .
Warning DANGER DANGER LEATHAL VOLTAGES
DISCHARGE HV Capacitor and disconnect from power ALWAYS
Posted on Sep 11, 2008
On our microwave we get all the functions working, but the microwave does not start.
Posted on Nov 24, 2008
I have a Maytag OTR Microwave oven that doesn't work. After I close the door and set the time and start, I see the time countdown, but I don't see the microwave starting. I can get the microwave to start,...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See our file on door switches here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 30, 2010 | Maytag Appliances Over-the-Range Microwave...
My Sharp R-1870F microwave in our rv heats intermittantly and the turn table is stuck. Any advice?
Check the oven door if it locks up, the oven has an automatic feature that when it is not closed properly it won't initialize. Since it heats up intermittently I think the heating capabalities of the microwave is still good, and this problem might be just due to something that is preventing it to operate. which most likely the the locks of the door.
Jul 07, 2010 | Sharp R-1870 Convection/Microwave Oven
GE JVM150001 Microwave
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Can you scan and e-mail or photocopy & fax the "schematic diagram" portion of the mini-manual to me?
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
fax 866-481-2802
Sep 28, 2008 | Microwave Ovens
My microwave is brand new. When I close the door, the dish rotates and the light stays on. Help!
Test 3 Door Switches. Intermittent, Skipping, Maybe Burnt internally or Spade contacts Burnt. Door switches should Open/Close or Closed/Open. A Meter or Continuity Tester Works. Audible Sound Hearing Helps on Continuity Tester. Listen for Nice Clear open-Close or Close-Open sound. If no Sound or Skips ( Intermittent ) Just found Your Problem. One of the Door Switches is Not working right. Now You Can Make & Save Money by Doing it Yourself.
Aug 15, 2008 | GE Microwave Ovens
Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Sharp R-9H66 Microwave Oven
Frigidaire FMV157GM Microwave Oven Logo
1,536 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Electrolux
Electrolux
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
