Question about Epson Stylus C80 InkJet Printer
Print head jam
Problem: Print head jams when trying to return from first pass at left end of carriage when starting to print general error message, (delete all print jobs and turn printer off, etc) There are no foreign objects or visible problems Red Ink error light comes on and is non flashing, red paper light and green printer light start flashing. Turn printer off, then on, paper feeds halfway, red error lights go out, print head slowly crawls back to start, paper ejects, printhead makes one pass to end of carriage, returns and parks, printer light stays on non flashing, no error lights. I have left it disconnected, I have tried re-installing, nothing successful, same error repeats. It first arose after re-alignment process. Cartridges are in correctly.
  • 2 more comments
  • Dennis Ambler Apr 25, 2006
    Techman: Interesting site, I agree about the ink drinking, just hoped there may be a magic quick fix, like a secret mfr. re-set button or the like.......,
    anyway, guess it will have to go to the Epson graveyard.
  • Anonymous Oct 07, 2008
    printer will not print. red light stays on
  • Anonymous Mar 21, 2014
    printer head will not move,does not print.
  • Anonymous Mar 27, 2014
    Z52 printer won't print. Green light keeps flashing. Took cartridges out, then back in. Didn't help. Unplugged printer, didn't help.Pulled paper out backwards when printer stopped printing just after it started to print.
  • 1,218 Answers
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5005876-epson_stylus
Posted on Oct 04, 2010
    President:
  • 3,130 Answers
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Posted on Apr 23, 2006
  • Larry  Dillon
    Larry Dillon Apr 23, 2006
    opps I for got the www so the right addy ishttp://www.i18nguy.com
  • Larry  Dillon
    Larry Dillon Apr 25, 2006
    Nope im sorry Dennis theres not But I wish there was a secret reset on all the stuff I fix. Man I would still have hair!!!
SOURCE:
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
Info printer :E
Any malfunctions its gives error 'E'... Check paper jam, carriage struck, cartridges faulty and service related issues.checking carriage:Switch on the machine check carriage(the unit carrying print heads)moving left & right.. if its not moving, it might be struck in service station(service station located at right end and its allow carriage to rest on it during shut down as well as its cleans the print head nozzles). power the machine pull carriage out gently, don't force it..Clean encoder strip: Encoder is located back side of the carriage and its guides carriage to move properly, if encoder became dirty you will get error message, clean encoder with smooth cotton cloth.
Feb 03, 2012 | HP PSC 1215 All-In-One InkJet Printer
Carriage Jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 08, 2010 | HP Officejet Pro 850 InkJet Printer
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Printer made machine gun noise. will not print.
The print head is stuck - something has jammed it and the noise you are hearing is the carriage for the print head. Open the top and try moving the head by head sideways to see what has jammed it.
Aug 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Carriage jam
Hi...
Try to move the carriage maually left and right ..still does not work...service the printer.
Regards
debroy
Nov 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
I had a "carriage jam" error message.
My son wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
I had the same problem with my DVD player. The head was hanging up on the two chrome plated rods that supported the head. I put some 3-in-one oil on the rods, ran the head back and forth, and it has worked ever since.
Kevin
Aug 13, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Epson Stylus C80 InkJet Printer Logo
880 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
