Question about Zoom H4 Handy Recorder
Zoom H-4 Hi Dropped my Zoom H4 And now it wont work on battery power it will only work with the power adaptor or usb where can i send it to get repaired?
  • 3 more comments
  • ep38 Apr 07, 2009
    I dropped my H4 and it does not work!
    It was a relatively light drop as well on carpet. So I am bummed. :(
    Does not work when plugged in via USB nor AC power or Batteries, nothing!
    I guess I will have to look for that warranty...
  • djstasiak May 22, 2009
    Same thing happened with mine.  It was a decent drop onto hard floor, but still works when plugged in.  I'm gonna try the battery terminal fixes and hope that works...
  • norrrmando
    norrrmando Dec 14, 2013
    I didn't drop mine but after taking it apart and checking all within, it turned out to be adirty terminal
  • norrrmando
    connection on the battery door. I let some old batteries in for a while I guess.
  • Jarandre Mar 20, 2014
    I have the same problem with the H4 after the fall no power from the battery. I checked in the middle of no damage. It dodarkowo one very bad phenomenon. I strongly heats the coil L202 with an internal power supply module. Does anyone have a schematic diagram of H4?
    Problem Solver:
  • 9 Answers
Take out the two screws then pry the case open and it will come apart. I don't think it is the switch btw. I think there is something wrong with the voltage sensing of the unit. Mine won't power up on alkelines but will power up on nimh's of slightly lesser voltage, but then says battery low.....
Posted on Jan 19, 2013
Ask your dealer, the one you bought it from. They may suggest an easy fix or guide you best on how to get it repaired, or at the very least suggest a place near you to have it repaired. If your dealer doesn't know, ask any Zoom dealer for repair info. Meanwhile, I assume you've checked your battery compartment to make sure the terminal connections are not loose (and of course that you've tried new batteries - :) ). Also, check Menu>Battery to see if alkaline or nickel batteries is checked. Finally, try removing your SD card and re-inserting, (even re-formatting the card, perhaps, but trying merely re-inserting first). But make sure any songs/info on the card are backed up first, because you will lose info if re-formatting the card. (For that matter, you could try a new card.)
Posted on Sep 12, 2008
My Zoom H4 will no longer power up with batteries. (yes even fresh batteries) only works with AC adapter. There was only one possible solution that makes sense and that would be concerning the little switch that disconnects the battery power once external power source is plugged in. I'm sure that I can repair this except, I can't seem to take the darn thing apart to do so. I've removed all visible screws and can't seem to dismantle it. It seems very fragile and I would hate to crack the casing. Does anyone know how to open this thing up?
Posted on May 18, 2012
  • Dragonstyne Aug 17, 2014
    I had the same problem. It was the battery connection on the flap. It looked clean but, closer inspection revealed it was corroded. I took fine sand paper and cleaned it and the H4 now works fine on battery power now.
Hi! I placed a bid on Ebay, on a used Zoom H4 and didn't read the fine print! I now notice that the seller says that the condition is good, but the battery operation doesn't work - it only works with the...
Usually the problem will be with the battery contacts. Often corrosion due to leaving batteries in too long or the spring contacts, don't. Another harder thing is the adapter connector often has a spring blade that contacts the center pin when adapter is unplugged to switch to battery. These get bent and are a chronic problem for devices that use either adapter or battery.
Apr 13, 2011 | Zoom H4 Handy Recorder
Hello. I have a problem with my ZOOM H4 recorder. When I try to turn it on (using ZOOM adaptor) it shows the the battery is low (but batteries aren't included) and tells me to turn it off. Also, when its...
I have exact same problem, I got it to work temporarily by turning unit on then connecting AC adaptor into unit, it forced it to run, I formatted card and it worked for an hour now back to same old problem, I'll keep you informed. I believe it's faulty switch. help me if you can.
Oct 07, 2010 | Zoom H4 Handy Recorder
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
My Zoom H4 will no longer run with batteries. If I use AC adaptor it works fine but I get nothing on battery power
Probably the connector where you plug the AC adapter into has a switch contact that disconnects the battery when external adapter is used and it has gotten bent so when the adapter is not plugged in, it no longer makes contact to the battery power. This is pretty common for devices that use both battery and adapters.
Aug 23, 2009 | Zoom H4 Handy Recorder
H4 zoom battery operation
try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Jul 02, 2009 | Zoom H4 Handy Recorder
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Jun 02, 2009 | Zoom H4 Handy Recorder
Connect to PC does not work
You need to upgrade the H4  firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
May 06, 2009 | Zoom H4 Handy Recorder
Title: Zoom H4 / Mac USB Problem
Upgrade firm ware from Zoom website
Good Luck
Mar 07, 2009 | Zoom H4 Handy Recorder
Cannot connect to PC
Do you have an SD slot in your mac? plug the sd card there and see if it works. Erase manually the files (leave the system files) and try again with the H4. Luck
Sep 12, 2008 | Zoom H4 Handy Recorder
Display reads "No Card"
Zoom h4 supports cards up to 2GB. And, I'm almost sure, this is a thing that can't be upgraded through software.
Apr 26, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
573 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
