Question about Sony Computers & Internet
Left mouse button and mouse pad sometimes stops functioning on the sony vaio vgn-ar51e
  • Anonymous Jan 19, 2009
    Although I have a different model I have the exact same problem. Originally it was only an issue now and then and sometimes restarting would correct it but the left mouse button has now not worked for about a week. I've had the laptop about 2 years but luckily took out the extended guarantee so will be sending it back for fixing.
    Master:
  • 788 Answers
It's most likely a loose cable inside the notebook then makes contact intermittently. Or, your touchpad is faulty.
It might be worth having the machine looked at by someone certified to take it apart.
Posted on Sep 11, 2008
Why does my vaio keyboard and pad stop working
Connect External USB keyboard and Mouse and use for a while.
If all keep working problem is likely with connectors or Motherboard
Jan 30, 2014 | Sony Vaio VGN-NW125J Laptop 2.1GHz Intel...
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Jun 25, 2010 | Sony VAIO VGN-NR385E Laptop
Sony vaio AR51E mouse cursor doers not move as touch pad not respoNding, EXTERNAL usb mouse works fine any ideas??
Go to Control Panel
SEE mouse icon... OPEN this
see if the touch pad is disabled
Try to go to the site Sony VAIO model specofic download latest driver for the touch pad
there are specific setting to enable the pad somehate it some love it but you can sort it out by looking at Control Panel /device manager etc
if USB mouse is working at least you can navigate to find issue
Jun 11, 2010 | Sony VAIO VGN-AR720E/B Notebook
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
Feb 06, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
My left mouse button on sony vaio vng-nw150j isn't working
Generally, if a mouse button quits working, it requires the replacement of the touchpad assembly.
Boot to the safe mode, see if the button works there, if it doesn't, then it is a failure of the switch in the button
http://cgi.ebay.com/TESTED-Sony-Vaio-VGN-NW150J-LCD-Keyboard-Palmrest_W0QQitemZ120522991092QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0fbae5f4#ht_1088wt_1165
Jan 29, 2010 | Sony VAIO VGN-SZ460N/C Notebook
Eject button on Vaio won't work
t seems like people are having problems with getting the Fn Brightness and CD Eject Keys working when installing XP.
The following files and install method works here:
01. Install SFEP [AR51] (Right Click - Install SonyNC.inf)
02. Install Sony Shared Library [AR51] and Restart when prompted
03. Install Sony Utilities DLL & Settings Utility Series [BX4]
04. Install VAIO Event Service. Select Custom and Check VESUnique and Sound [BX4]
05. Copy AR51 Vista VESConfig.ini (from attached zip file) to folder C:\Program Files\Sony\VAIO Event Service
06. Start - Run services.msc
07. Find Vaio Event Service in the Services list and Restart the Service.
Your Fn and EJECT Buttons should now work.
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
102 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
