Distinctive Ring
basicsDistinctive Ring service is an
optional service available from many telephone companies. The
Distinctive Ring service permits you to assign more than one telephone
number to the same telephone line. Distinctive Ring allows you to use a
single phone line for both voice and fax calls. You can assign a unique
phone number and ring pattern for incoming fax calls. When a fax comes
in, each telephone number makes a distinctive ringing sound, such as a
single ring, double ring, or triple ring.
NOTE:
The Distinctive Ring Service
is the name HP and others use to describe this feature. Distinctive Ring
is also known as:
- Call Sign
- Custom Ring
- Ident-a-Call
- Ident-a-Ring
- Ident-a-Ring
- Multi Ring
- Personalized
Ringing
- Ringmaster
- Smart Ring
- Teen-Ring
The Distinctive Ring Service allows the HP
product to work similarly to a dedicated fax line.
If you connect an HP fax product and a telephone to one telephone line,
you can assign one telephone number for fax calls and another for voice
calls.
NOTE:
You cannot
send or receive faxes when the phone line is in use. Even if the HP fax
product has a separate telephone number, it is still sharing the same
phone line.
Set the Distinctive Ring
Service Using the menus on the
product control panel, follow these steps to set a distinctive ring
pattern.
Step one: Turn on Auto Answer
Turn on Auto Answer by pressing the
Auto Answer
button on the control panel. The button light indicates when Auto
Answer is on.If the button light is
already on, you do not need to press the button.
Step two: Set the distinctive ring patternFollow these steps to change the answer ring
pattern.
Press the Setup
button (
) on the product control panel.
Press the Right Arrow button (
) to select Advanced Fax Setup
, and then press the OK
button.
Press the Right
Arrow button (
) to select Distinctive Ring
button.
Press the Right
Arrow button (
) to select one of the following options:
- All Rings
- Single Rings
- Double Rings
- Triple
Rings
- Double & Triple
Rings
Press
the OK
button to select the option.
Press the Back button (
) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
