I bought a Printmaster Silver yesterday and I can't get it to install on my computer. I have windows xp which it calls for but when I put the cd in it acts like its going to run but it don't. I tried installing it manually but it won't take it like that either. What can I do? Deborah
  • jugndudy3 Nov 19, 2008
    I have the same problem with my Printmaster Silver 12. Can you please help me?
I called a friend that is good with computers and he helped me. Thanks for getting back with me.
rockya4041
Posted on Sep 14, 2008
I am running windows 7 and I would like to know how to install an old version of printmaster silver 10 on windows 7
Printmaster 10 may not work with Windows 7. Just uninstall Printmaster 2012 then install Printermaster 10 using the installation CD.
I recommend you go to the Printmaster support site and ask them if version 10 will work with Windows 7 so you do not have to uninstall 2012 version if version 10 will not work with Windows 7.
Oct 15, 2012 | Dell Inspiron 1720 Notebook
I just bought a dell laptop using windows 7. How do I install PrintMaster Silver 10.
just put the cd or dvd in the disk drive & it should start automatically
& just follow the prompts.
Oct 15, 2012 | Broderbund Print Master Silver 16.0 for PC
I have used PrintMaster 10 for a number of years on my old computer-XP. I recently purchased a new computer and wish to put the program on my laptop( Windows 7). I tried choosing the compatibilty method...
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
Apr 11, 2011 | Broderbund Print Master Silver 16.0 for PC
I had Printmaster 10 installed on my computer, but recently had to reload, I saved my invoice files to a disc, but they will not open up unless I reinstall Printmaster 10. I have Windows XP, and the disc...
I suspect that when you re-installed 10 it corrupted in some way and did not install properly. If you are using the same computer as before and the same software disc as before, then unless you had an update, which changed printmaster 10, it should be the same as before.
The only updates to Printmaster 10, would have been around a few years after it came out. There are no software updates for any software that still works only on XP as the system is now redundant.
Try re-installing Printmaster 10.
May 19, 2017 | Broderbund Print Master Silver 16.0 for PC
My new computer runs with windows vista by my printmaster silver 12 cd does not work. What do i need to do?
If it will not install
  1. Find the Setup program.
  2. Right-click on the Setup program> Properties> Compatibility tab> select "Run this program in compatibility mode" check box.
  3. Select the operating system that the program ran on previously, and then click OK.
Also see
  • http://support.microsoft.com/kb/931361/en-us
Apr 11, 2010 | Broderbund Printmaster Silver 12.0
Printmaster 17 won't open projects created in printmaster 11.
printmaster 1 was for windows 98, ver 17 is for XP. it depends where your saved projects are. if they are on CD media then that is READ ONLY and they must first be transferred to a C:\ drive and their ATTRIBUTES for each and every file/folder of the project need to have the Read Only attribute removed. you can do that via CMD.exe eg if your project was inside a folder called c:\myprojects\????? then you would type in ATTRIB/S c:\myprojects\*.* -R then your projects might be valid as they could be UPDATED/Altered by the new version but thats just a guess.
Jul 20, 2017 | Encore PrintMaster 17 Silver Full Version...
I purchased a printmaster platinum 12 in 2002 and loved it but now i am trying to download the software into a diffrent computer since out other computer crashed. i have my registration # but i can only...
I am guessing that your new computer has windows vista on it. That may be the reason Printmaster 12 will not install. Certain programs or their installations are not compatible with Vista.
I'm not sure what errors you are getting, and I am assuming you are running Windows Vista, so again I'm just guessing.
You could try to launch the setup program manually and using compatibility mode by following these steps:
1. Insert your installation disk.
2. Click the start button
3. Click on Computer
4. Right click on the drive containing your installation CD
5. Select Explore from the menu.
6. Find the Setup or Install file in the list.
7 Right click on it.
8. Select Properties.
9 Select the Compatibility tab at the top.
10. check "Run this program in compatibility mode for"
11. In the drop down menu select windows xp
12. check "disable visual themes"
13. Check "run this program as administrator" (if it is available)
14 click OK
15 now double click on the setup/install program.
I hope this solves your problem.
Thanks!
Nov 03, 2009 | Broderbund Printmaster Silver 12.0
Cannot install on new laptop which vista windows
Hi there, i think you have to buy the new version of it, it does not work with vista you can see it here (It writes windows 98-xp):
http://www99.shopping.com/xPF-Broderbund_Broderbund_PrintMaster_Silver_15_Jewel_Case
And
You can buy a new version here, But as far i can see in the system requirements they do not mention windows vista, so I do not know if it will run under vista??
http://cgi.ebay.com/Broderbund-Printmaster-Silver-17-PC-software-NEW-BOXED_W0QQitemZ200389004657QQcmdZViewItemQQimsxZ20090929?IMSfp=TL090929146004r3159
OR
http://www.amazon.com/Encore-PrintMaster-Silver-v17-DVD/dp/B000EGK3KM
Hope that helps
IF Not then return here
Have a nice weekend
Please rate my answer
Oct 03, 2009 | Broderbund PrintMaster Silver 15 for PC
I have purchased PrintMaster Gold version 18 three times and returned two of them. My computer is operating on Windows XP service pack 2. My computer does not seem to find any data on the install disk....
You might have a problem with your CD/DVD drive. Try inserting the CD in another computer. If the files are shown, replace your CD/DVD drive or just add another CD drive to an empty bay of your computer.
Jul 31, 2009 | Broderbund PrintMaster Platinum Version 18
Cannot install PrintMaster platinum version 18 on 2of 3 computers
on your desktop go to run and look for your software then run it
Jan 06, 2009 | Broderbund PrintMaster Platinum Version 18
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
