Question about Canon ZR830 Mini DV Digital Camcorder
Camcorder wont show images
The camcorder will not show any thing, there is only dim light coming through and a grey screen when ever you try to record, playback works fine.
  • 4,234 Answers
This sounds like the iris is stuck almost closed. You can try gently tapping the side to attempt to release the iris. If that fils to resolve the problem, the unit should be brought to a servicer to rebuild the optical block.
Dan
Posted on Sep 11, 2008
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
CCD-TR705e Sony video recorder hi 8 playback 3 beams
the camcorder flickers when viewing playback - pictures flickering
Dec 10, 2008 | Pure Digital Point and Shoot Video...
Grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
Jan 12, 2008 | Canon ZR200 Mini DV Digital Camcorder
Recording
There is a recall on some Canon camcorders. Call Canon technical support. They will fix for free as well as free shipping. I had the same problem.
Nov 15, 2007 | Canon ZR830 Mini DV Digital Camcorder
Blank LED screen
If it also does not work for playback then there may be a wire broken in the hinged part of the screen. About a 120.00 fix
Nov 10, 2007 | JVC GR-D370 Mini DV Digital Camcorder
SAMSUNG VP-D353 DIGITAL CAMCORDER
BAD CCD ( CHARGED COUPLER DEVICE ) THIS IS WHAT ALLOWS LIGHT IN YOUR LENS TO GET THE IMAGE
Jul 09, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Canon ZR830 Mini DV Digital Camcorder Logo
82 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
