Laptop power point no power getting through - Computers & Internet
    New Friend:
  • 68 Answers
Check the availability of power in wall socket and replace the adapter if needed.
Try & reply.
Posted on Sep 11, 2008
Aspire on charging point problem
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Nov 29, 2012 | Computers & Internet
Male tip of charging point for Acer a500 broke off
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 09, 2012 | Acer Computers & Internet
I have a hp nc4000 laptop. its not powering on. the battery orange light only blinks and then nothing . can you help me please??
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 21, 2011 | Computers & Internet
I use a Compaq CQ60 laptop. Recently I noticed that when I plug in the power cable the charging indicator at the point won't come on. Yet touching the Earphone slot with the back of my hand indicated that...
Hello.
If you are not getting total power, the most common reasons are the power adapter/cord and power jack.
Hope this helps.
Jun 30, 2010 | Compaq Presario CQ60-220US PC Laptop
I have averatec laptop. The point where battery adapter is inserted start getting hot and burning smell comes..
The power jack has failed. You need to get a new one fitted.This you can do yourself or better still, get someone who knows laptops...computer repair shop or a mate.
Jan 04, 2010 | Averatec 3200 Notebook
No power to computer . Ac adaptor plugged in and power point ok- just no power at all to computer- wont turn on.
If the power point is ok try using another AC adaptor of some of your known person who is using the same laptop, and check it should work else the fault will be with laptop and you need to get the same checked at the service center,
make sure you do not open the laptop on your own as you may loose the warrenty of the same
Let me know if this will help
Regards
Nov 29, 2009 | Dell Inspiron 1501 Notebook
Unable to open power point presentation in movie maker
You cannot open power point presentation if you do not have power point or ppt viewer installed. download the ppt viewer from the below given location.
http://www.softpedia.com/get/Office-tools/Other-Office-Tools/PowerPoint-Viewer.shtml
Revert back for clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Compaq laptop screen not working
compaq presario c304nrharddisk is not detecting
Jul 04, 2008 | HP Compaq Presario C304NR Notebook
Have an MT6451. When I press the power button it will not turn on but the battery indicator light in front of the laptop flashes red every time I press the power button. I should also tell you that it did...
Gateway MT6451 laptop. That was easy but the rest is a guess without more details. It sounds like this computer is not plugged into an outlet or is not getting power from that outlet, and that the battery is dead low. Try plugging something else, like a lamp, into the very same outlet that the laptop is plugged into to make sure it turns on. Not the next plug over on a power strip, but the very same plug. If it doesn't get power either, there's hope. Except that your battery needs a good recharge after the laptop starts getting power.
If the outlet turned out to be good, then the power adapter on your laptop may have failed. At this point you'll need try another power adapter and try again. At this point you may need the help of people who can look at the computer for you, preferably friends with a similiar laptop (and power adapter).
I wish I could help more, but thats a start.
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
